  • Replies 53
I have a trust return flow intercooler and has made up to 290rwkw on the dyno without any issues. We pulled out some timing and reduced it to 279 and its been great.
The previous owner also on here made 310rwkw with it.
It seems to be a discontinued model as I cant find them still for sale anywhere. I think the blitz one will do it also.
What cooler do you have now?
Rebuild?? Please explain
Mines making 350ish on E85 with a Blitz Return Flow, its showing no signs of restriction at that level.
Hamish's motor may have knock from the bearing, hence he's talking about rebuilding his 25.
Harey, his FMIC is currently the one that goes through washer bottle (R33 by the way).
Hamish, you going to dirty 30 and pray Melbourne's finest doesn't pick 20mm taller motor?
plan at this stage is to rebuild and do the 3.0 yes.... and there is no way they will notice the extra height
currently i'm running a hybrid GT cooler
Any info on what happened mate? Or still a sore point
Have you decided on what turbo you will use with the 3.0L?
not sure really... as i was driving home (sedately) i was just ambling along in second about 50m from home and heard a slight "thunk"
i figured it was just a rock hitting the front bar so parked the car and went inside
next morning i turned the key and i could hear a faint knocking coming from the engine bay. i popped the hood and listened for the sound and it was coming from the back of the motor.
i eased on the throttle cable and the knocking got faster... i then turned the car off and it hasn't been fired up since.
oil pressure is correct, oil and water both look good, no leaks, oil level is perfect.
the plan for the 3.0 is to build a setup that will be responsive as all hell, and reliable! hence i plan to use the same turbo, even though it may be a little small, and possibly prone to creep, i think the delivery will be phenominal
.68 will be too small for a 3l, need a 3076 in a .82 like Al ;)
i dont want to make as much power as al, as i cant afford a top dollar build at the moment.
i'm planning to use the small turbo for lightning response, and sub 300rwkw for longevity
Pretty easy to work out what went wrong :)
15yo motor making over double the factory power...
this....
well i always said it was gonna happen eventually... and anyone that knows the car knows it had a good life.... hard... but good ;)
mostly i'm just srprised it didn't happen banging off the limiter mid slide... it just decided one morning it had had enough lol
problem is i just wont know till it's pulled down and from that point, the difference in goin 3.o isn't all that much
That doesn't really sound like a big end... Sure you don't want to get it checked out before possibly forking out when it might be something fixable?
Anyhoo sucks when it happens :(
If I was you I'd be going another stocker RB25, so much easier than a RB30 and I bet a hell of a lot cheaper!
Edited by SimonR32
Could be heaps of things, maybe take it down to Trent or a mechanic and ask them for their opinion :)
Or are you just using a noise as a excuse for a upgrade :P
PS: To check if it's a big end you could always do a limiter skid down the road, if a rod comes out the block it's probably a big end haha
trent's gonna have a listen when he's in the area next... he's heard it over the phone and said it didn't sound great...
i am of course looking for an excuse to do a 3.0 but if i can fix it for a grand i'll be going that route....
i'm not really thrilled at the idea of a kinder surprise, which is why build comes to mind i spose
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
