  • Replies 74
stream seems very temperamental this year,
race is starting to take its toll on the cars,
unfortunately the 2nd Wall Racing car, the east holidays EVO had a small fire issue atop the mountain
just got word from the JB car its no longer an 8 cylinder Ferrari, trying to fix it to finish the race.
GTR has has both mechanical issues and contact with a leading car (not the GTR's fault)
STI has fuel problems
unfortunately the Mosler was out before i was even up this morning, with a big off on conrod, which even left the windscreen stuck on top of a telegraph pole
Edited by Whiplash
close finish alright. Pete Conroy's Emo X (first production car home) was only 40 laps down on the winner, 22 seconds a lap slower
still surprsingly few retirements. GTR was 2nd retirement.
whiplash were you helping with the mosler? what happened?
I was up there for the first hour and just as I was walking past the citigate when the mosler went off. A tyre let go coming down conrod.
I really wish there was just production cars inthis race. I might have stayed longer.
So what exactly went wrong with the R35?
On that topic it has to be said by someone, why is the DK R35 so slow? is it because of production spec constraints?
Also any more detail on the Mosler incident, tyres?
Edited by LSX-438
I dont think its slow, i think its more that its up against much better/faster purpose built GT3 cars.
Anyone have lap times for it? doesnt matter what circuit, just intersted to know how it stacks up against either your car Dunc or other R35's
I'm more keen to check it out as it's not production car racing. The Eastern Creek 8 hour was a major snooze.
I'd consider it surprisingly slow, seconds a lap slower than a few road going R35's (in an outright/qualifer sense anyway).
is it just because it's stuck with production specs? they run slicks right?
There was some smoke coming out of the GTR from the begining, which didn't really look right.
I can understand that but form the pics and highlights I saw the 2010 Bathurst 12 hour looked a lot more interesting with 41 entrants as opposed to the 26 this year (of which 11 were production). Obviously the GT cars discouraged many production entries.
The GT cars were lapping the production cars within a few laps making them look like some second rate side show. Especially when the race was re-intorduced for production car racing.
That's a fair point for sure. I think anything with a large enough field is exciting to watch - the EC 8 hours was boring as there were only 13 cars in it, and 8 which finished the race. Those sorts of numbers are never going to make for great spectating, especially when there is such a speed differential.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
