Hi Guys,
This is a list of tutorials/DIY's written by forum members.
  • General
Nissan Service Schedules - by Bo_Shanab Painting calipers - by predator
Brake Pads - Bedding In Instructions - by GenesisR32
How-to: bolt a VLT turbo onto your RB25DET - by Revhead
HICAS Info - Including Diagnostic - by Lozza150
How to bypass HICAS - by Lozza150
Buying a Skyline: What to look for - by Merli
Where to Find Insurance - by Various Artists
Trackday Preparation - by Various Artists
Types of Skylines and their specs - by Duncan
G.R.I.D Dash Dancer ETS (Torque Split Controller) Installation - by YO880
Wheel Offsets for Dummies - by B-Man and others
Leather Gearstick and Handbrake boots install - by Jay95R33
Pillar/Pod Installation - by Messiah & others
ECCS Diagnostic codes for 1989 - 1994 models - by Skyline_Boy
Thermal shield for FMIC pipes - by skylinegeoff
Cluch alignment - by R33vit
Removing a GTR Engine/Gearbox/ Plus more - by s13drifter
How to repair a front bar or other fibreglass cracks - by predator
DIY RB30 Converstion - by JNR34 & others
RB30DET Guide - by Cube
Choosing a Turbo - by nuffin_werks
Changing your Brake Pads! - by HCR32
Replacing Steering Rack boots - by HCR32
Oil Cooler Instalation - by Blk33
Restoring Alloy Wheels - by daxter
Wheel Painting DIY Tutorial - by MyStag260
Rb25det Belts Change - by shubby0901
Led Lights In Footwells - by shubby0901
Restoring My Carbon Fibre Hood - by Joni Boi
R32 (maybe R33/34?) boot/trunk lid lock remove and rekey - by HABU32
Howto - Install Gizzmo Klite knock sensor - by MrStabby
Toyota Echo/Yaris Coil pack conversion for RB25DET - by iMick
Reading Nissan Fault Codes Ecu Fault Codes How Read Them - by *nigz*
Brake Lever Leather renewal DIY - by Fastlane
  • R34
Installing Boost Gauge, D.I.Y. - by Satanic
Replacing spark plugs on NEO6 - by Kirill
How To Replace/drain Coolant From Radiator And Block RB25DET - by Joni Boi
Custom gauge fit R34 GTT only! - by stump_69
DIY demon eye mod - by adam wicks
D.i.y: Changing Coilpacks On R34 Gtt - by Sheng
  • R33
Diy Aac Valve Cleaning & Idle Reset., Auxillary Air Control Cleaning for RB25DET's - by insu
My First Skyline's guide to changing your oil and oil filter in an R33 - by Sciby
R33 Stereo Installation Guide - by NS2500
Removing Entire Dash - HOWTO - by predator
Heater replacement: HOWTO - by predator
DIY: Change your own brake pads (front and rear) - by benm
DIY changing front shocks - by JimX
Boost Gauge Installation - by YBSLO4
Removing turbo on R33: How to. - by JimX
Dual High Beam - by GTS 33
Removing door trim - by streamer
Removing front bar on S1 R33 GTSt - by predator
Removing the front bar on R33 SII - by EDS33T/others
R33 Rear Seat - How to remove ?? - by Various Artists
Fitting a short Shifter (R33 GTR) - by PranK
The differences between a Series 1 and Series 2 - by PranK
Changing spark plugs - by predator
Another sparkplug Changing guide for RB25det ( with step by step pics)- by Shane
Bosch 910 Fuel Pump install - by Various/predator
Gearbox Oil Change - by Jay95R33
Podfilter Installation - by MarkR33
R33 Radiator Replacement - by Nuffin_Werks
Rear Seat Removal in Skyline R33 - by jnr_j
HOWTO: RB25DET High Boost mode with standard solenoid- by paulr33
Intalling a Turbotimer - by Skyline_Boy
R33 DIY Bosch 984 fuel pump - by wolverine
Dual headlight high beam - by GTS 33 & Others
Oil Cooler Installation - by Blk33
How to Fit a Z32 AFM - by Col-GTSX
Removing console and dash - by pushead
Removing Rear Quarter Windows - by tuning_vs_hardware
DIY - How To Change R33 S-hifter Bush - by kingtube69
DIY - How To Repair R33 Air Mix/blend Actuator - by kingtube69
r33 GTR DIY engine instal motor and box together - by GD51LA
Installation of Child's Car Seat into R33 GTR - by Steve85
R33 Boot Lid Prop - by Super Roo
R33 gtst s2 morimoto projector retrofit - by Ty1
  • R32
Guide to Changing Gearbox Oil in a R32 - by GenesisR32
Guide to Changing R32 Headlight Globes - by red17
Guide to changing fuel pump in a R32 - by silver gts-t
How to CAI for stock air box on r32 GTST - by NJ
R32 Boost Gauge Install, Installing into the drivers side vent - by wilch
R32 Manual Conversion - by gaffa
Xenon Headlights Conversion - by Ronin 09
GTR Injectors into RB20DET - by Roy
HICAS Removal - by eXc
R32 GTR Battery Relocation - DIY - by Nelkel
R32 GTR Morimoto Mini D2S 4.0 Retrofit - by Carbonsky
  • Stagea
Fitting A New Lambda Sensor, Quick guide on what to buy & how to fit - by Sydneykid + Various
How To: Stagea Headunit/stereo Removal - by AlexCim
M35 Dump Pipe Diy Install - by datmoo
C34 Stagea Cruise Control Installation Guide from A32 nissan maxima - by daneprostamobrown
  • S15
Installing Yashio/Aftermarket Tail lights - by zappandcrew
Changing Climate Control Colour/Replacing broken LED | S15 - by zappandcrew
Changing Coil Packs and fixing a misfire | S15 - by zappandcrew
Installing/replacing seats in the S15 - by zappandcrew
If there are any more to add, PM me.
https://www.sau.com.au/forums/topic/35048-list-of-members-tutorials/
  • 5 years later...
  • 2 months later...
  • 2 years later...
  • 5 months later...
http://www.skylinesaustralia.com/forums/topic/192015-diy-changing-coilpacks-on-r34-gtt/
its for R34 but exactly the same but we done have a NEO cover, and it looks like that user took it off before hand anyways
  • Like 1
  • 10 months later...
  • 3 months later...
Hey guys,
Just curious does anyone have an electronic user manual for an R32 GTS with RB25 N/A standard?
If not can anyone point me in the right direction?
Cheers
Check out the downloads section on gtrpwr... You'll need to first make an account.
Sent from my SC-03D
  • 4 years later...
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
