Hard to say as who is the cheapest as this will change at different times.
Points to note:
- Other parts are required such as dump pipe, oil and water lines etc. Make sure you have a good grasp of whats required.
- Make sure the price is for the internally gated option.
- Do not buy a housing with the 6 bolt skyline flange, make sure you get a proper garrett exhaust housing and just simply buy a new dump pipe and bolt that up to a 3" front pipe.
Few people have got them through this place and reckon they were the cheapest in a kit and were good to deal with:
http://www.kudosmotorsports.com/catalog/garrett-turbo-garrett-gt3076r-nissan-rb20det-rb25det-525hp-p-535.html
GCG:
http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=233&category_id=28&option=com_virtuemart&Itemid=53
Thats for the 52T version, there is also a 56T.
They are ridiculous prices! Whats the catch?
Seems he keeps his overheads low by working from home and carrying minimal stock so some items sourced overseas might take a while to arrive. The upside of that would seem to be that you are not limited by what he stocks but can choose from the entire catalogue of his suppliers..
His turbo's come straight from MTQ in adelaide, took bout a week 2 get mine, he doesnt even see the parcel just orders direct from the source with a great price! my tuner still doesn't know how he sell's them so cheap. but other things he does have to source from the states like kiwi said but that is also fast shipping my mate got eboost street from states in like 5 days
I think MTQ fit theirs with the larger unported shroud comp cover, different turbine wheels and in between sized rear housing.
Reports say its less responsive.
If you want the 3076R, go the genuine Garrett specs as per their website.
GCG sell it unchanged.
TweakIt sell full kits.
Edited by conan7772
they sell you whatever you ask for. if you just go in and ask for whatever gt30 they've got then you havent got much chance of getting the right one. go in and ask them to supply the exact turbo you want and they will. they even modified myne for me to make the internal gate bigger.
An australian product shipped from the states , go figure... :no:
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
