I know this could be 1 of 1000 things.
but i was wondering if someone could point me in the right directions as to sort this issue!
Basically, the car has not really been driven for a long time. Finally iv got the car back on the road. changed plugs and oil and filter. Took it for a drive and it was running fine. Til i started to roll on the boost, it was as if it was ignition cutting(like on the rev limiter would. just my description of the issue)and when i backed off it started to back fire big, i guess burning the unburnt fuel.
im gonna start with the igniter module, check a few sensors and the grounding.
i was told it may possible be a dud injector leaking internally into the rail then into that cylinder once backed off??? i didnt really understand the description properly that i was given on this
any help would be greatly appreciated!! cheers guys
https://www.sau.com.au/forums/topic/350688-rb26-misfiring-on-boost/
  • Replies 53
coils are around 35g km's old and are split fires. i will check them but iv been told they should be fine. but ill still check of tracking marks etc...
the car was off the road, 1, i lost my license 2, i blew a stock intercooler hose and was waiting for replacement and 3, the clutch was starting to slip once it had warmed up so i wasnt using it. No mods or anything
Very Similar situation,
Car was offroad for a long period (although regularly run) and now starts to splutter and misfire at approximately 4500RPM (boost) Have changed plugs and check the splitfires (which are quite new around 10000km old)
Any suggestions ?
Are the plugs old? Could have been sitting in oil/fuel/water all that time for whatever reason fouling them. Though if it was oil or water you probably have bigger issues, possible a very very small leak could have covered them in that time though. Also if it was very hard to start first time you could have fouled them running rich.
Definitely sounds like a spark issue, I'd look at new properly gapped (0.8mm) plugs first, if the coils are new this shouldn't be an issue, next is is there water in the valley? condensation on any of the ignition components?
edit: If the intercooler hose blew it probably ran rich as shit fouling the plugs. The other thing is are you sure you fixed it properly? As a boost leak causes similar symptoms, stalling, missing, blowing dickloads of black smoke when going on to boost.
Edited by Rolls
since you just changed the spark plugs and now have this issue that's where I'd be looking. check they are the correct type and heat range and that they are gapped appropriately for your set-up.
Hey guys, Sorry to drag this back up,
Have checked the following and it is still blowing out spark albeit at around 5500 now rather then 4500
Splitfires
Ignitor
plugs, changed AND gapped
removed and cleaned AFM and tightened all plugs (voltages all read correct)
Removed inlet piping and re-tightened hose clamps (helped somewhat) still wont run more then 0.5 bar though.
What about gaskets on the turbo compressor outlets to twin turbo pipe, these two are a bit suspect.
any ideas boys ?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
