Ten tips to a good day
1.)Oil level is at the Max mark on the dip-stick
2.) Coolant - ensure the overflow/reservoir is full
3.) Brake Fluid - ensure the fluid is at the Max marking in the reservoir
4.) Clutch Fluid - ensure the fluid is at the Max marking in the reservoir
5.) Check that all pipe-work is secure and no hoses are becoming loose
6.) Check that your battery is secure and does not move
7.) Make sure that all caps are on and secure
8.) Suitable material left on your brake pads
9.) Tyres are in good condition and wheel nuts tight
10) Nut behind steering wheel secure
9 out of 10 aint bad
See you all tomorrow guys and girls
1 1/2 ltrs of oils in the can 2 1/2 ltrs in-on-around-under the car with god knows how much I dropped on the track.
First lap was slow as they left the red light on most the way then when it was turned off I gassed it to the last turn braked then mashed it down the straight, slow into 1-exit 2 and headed up to 3 with the arse slipping around which I put down to cold tyres, went around again with the arse playing silly buggers then at the exit of 2 heading to 3 it tanked slapped me around a bit and I went off, I got back on allright but it done it again in the exact same spot AND I lost powersteering so I came into the pits to see WTF was up.
Popped bonnet and the cold side was covered with oil and both the powersteering and aircon belts were off, on further inspection the aircon belt was torn to peices and wrapped around the fan with little bits everywhere while the P/S one had its arse handed to it but not as bad(had alot of the cord ripped out).
Oil came from the catch can which is where I got the 1 1/2 ltrs (volume of the can) from.
Filled up the car with 4ltrs of oil (sump holds about 7), moved the bits of eaten belts and came home.
All in the first 3 laps.........................................................:rant:
Mark
The oil sprayed onto the belts causing them to slip off. Let us know what they do about ur engine.
Had a great day today. Few bingles at the end of the day unfortunately. No body hurt luckily.
Time for me to get some decent tyres on the front to get rid of the oversteer and hopefully my wilwood brakes turn up this week. My brakes were a big let down.
yeah thanks people it was ace, no injuries to my pride other than a flat spotted tyre and the odd backwards moment into the dirt.
i wish some other people (Eric) could say the same..poor bugger, keep us posted on devs and if you end up getting any kind of recompense from the offender.
managed a personal best of 1.15.8 so pretty chuffed with that though i know theres lots mores in it!
bring on the next track day ASAP!
pics etc up after i pass out..
Forgot to say I have some pics on my facebook, not sure if you can see this, if not feel free to add me! http://www.facebook.com/album.php?aid=272781&id=652446637&l=04a9065e42
And also MASSIVE thanks to Steveo for standing there all day on pit lane, and to AggroDave for sorting out all the entries and forms and shit. You guys rock for the time you put in!
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
