What happens if I run 18 x 8? Should I be going 235/45/18 instead?
For M35's... (speedo values are based off the OEM speedo calibration for MY NM35)
STOCK RS
17" rims = 55 sidewall (total tyre height is 668mm) - speedo reads 10% fast
18" rims = 45 sidewall (total tyre height is 677mm) - speedo reads 8.7% fast
19" rims = 40 sidewall (total tyre height is 679mm) - speedo reads 8.3% fast
20" rims = 35 sidewall (total tyre height is 680mm) - speedo reads 8.2% fast
The ~10mm extra total height over the stock RS 17's fills out the wheel arch perfectly (particularly if you have lowered your suspension 20-25mm)
  • 1 month later...
STOCK RS
oh on this i think for the arx its +5 on the sidewall for each..
mine are 19" with a 45' sidewall.
and against the informeter with a GPS HUD dispaly it was i think 3-4km out at 100km/h
Would probably work out the same for RS and RX's
but your running a 19 and a 45 sidewall
thumbsup.gif.....but I am running a 245 as well!....more width....higher wall!
I may even go to a 35 sidewall if the new diff's throw out my speedo!wacko.gif....more go!
Edited by Jetwreck
nup....standard size for the AR-X is 225/55 18"
Yes, I know... I was referring to the speedo accuracy.
Mine reads 10% high according to GPS, as have most other RS's I have been in, so adding the extra diameter will get the speedo reading close to what Aaron stated.
oh....yeh the speedo is good in the AR-X until about 95km/h's....after that it out.....what's confusing is that the Infometer was spot on to my GPS.
well yeh, if it makes any difference mine is a 235/45... which was lucky coz no chance am i getting a 245/45 under my guards at my height.
but yeh, comparing with scotts even, im kind of glad that my speedo is only 3-4k's out..
Rolling diameter, not tyre width :)
235 or 245 shouldn't make a difference to your speedo.
  • 1 year later...
ok so if i change the 265 for something smaller will that be ok. and i just read about roling diameter being different from front to rear am i going to have a prob with this? and i just found out the rears are 18x9.5 + 38 offset running 265/35/18 and the fronts are 18x8.5 + 34 offset running 235/40/18. is this going to cause probs?
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
