i have searched but could not find what i was looking for
i currently got suspension that is way way too stiff for road use, so looking for lot more softer ones that are road oriented
what are my options
1. can i make the current ones softer by putting in different springs, if so who does this sort of work
2. Buy stock R34 GTR V-Spec suspension
what is cost for both option going to be
Also looking at the SAU, it seems lot of people recommend this spring rate
Spring Rates:
Front: 8kg | Rear: 6kg
See picture of Current Spring and Car Ride height "Height is set to the maximum height, which i am not too happy about as it still too low"
Tein Superstreets should be the easiest solution and sell your existing if you can.
got a quote from these guys
http://www.fulcrumsuspensions.com.au/tein.html#superstreetkits
there are 2984 bucks fitted, that a bit more than i was expecting Damien
If it is a road car with the occasional spirited drive get a set of Bilsteins with 6/4 spring rates front and rear; may as well get a camber kit too to correct your camber if you want to lower the car slightly. Stay away from Jap brands.
recommend any retailer / shop that do these
I recommend the Nismo S Tunes as they are very compliant on the road to soak up the bumps and firm enough to be sufficient for a spirited drive. Spring rates I thibnk are 8K F/R
I don't mean to blow my own trumpet, but I have a set in mint condition for sale for $1500. Checked and OK'd by Racepace.
Pm me if interested
Import them. I got my Super Street for 1.4k landed. I dont think the aus spec super street are worth the extra 1k. PM me if you want more details. As mentioned by Choyda, super street is the best for comfortable. handling and ride height (being fully adjustable). They will make the height illegal if you drop them to the lowest.
No argument with above posts.
An alternative I used with my previous R34 GT-R was to use standard shocks with "Tanabe Progressive Springs"
Obtained from Powerplay Imports. Costed me $300 incl. instal.
The car ended up 18mm below V-Spec height & front lip was 105mm above the ground. Camber was not altered much at all.
> Comfortable ride without sacrifice to cornering. The only downside is to be extra careful with speedhumps and certain driveways.
8/6 is still pretty stiff, and IMO too stiff for a street only car. I'm guessing you're more likely to like 6/4. It would well be worth getting a ride in cars with those rates as everyone has they own idea about what they call stiff and what they like.
If it were me i'd think about using different springs with the suspension you have, since it looks alright. Any identifying stickers?
will give Accurate suspension in Underwood a call
they seem to have good reputation on re-building my existing shocks
if that price is too much, might import them
ERD does suspension !!
say no more then,
i am going there next month hopefully, i got few thing for Dan to fix on the Car
will get him to have a look then
BC BR from Just Jap with 6/4 option springs (should be able to ask for whatever rate you like).
Local tire alignment place will put em in for no more than $400. Or you can put em, got a jack? Got a socket set? You can put em in.
www.justjap.com
Also your current set of shocks don't have a threaded body, most if not all of the newer units do. This allows you to raise / lower the car without changing
the spring loading.
say no more then,
If you're looking for shock/spring combo, look no further because Dan does!
I would advise strongly against the Tein Super streets. they are cheap twin tube shock and absolute entry level teins. not great really. the upper level tein stuff is great but their entry level stuff is not so great.
I'd also stay well away from the BCs and the other china brands.
You want comfort. My advice would be:
set of used V-spec shocks and springs. will be cheap. certainly less than $1000. Id say more like $500-$800 for a good set.
Set of nismo S-tunes with the springs (like what Matt is selling). they are a good shock and give great handling. they are a little firm but by no means uncomfortable.
or a set of bilsteins with some suitable springs (around 6kg front 4kg rear is plenty but seek some good advice on that) and valved to suit. Cost probably around $1500 for shocks and springs but are quite good.
if it were my car I'd probably go the S-tune option. Nismo parts like these are designed for road cars and have comfort and safety in mind when built. they are a good set-up for a road R34 GTR. I have had a set myself in my old silver R34 (now owned by GTRNUR on this forum).
yeah I still think something like matts S tunes or the ones on yahoo would be the go. they have remote canisers on the front, have suitable spring rates, they also lower the car about 30mm and are great quality. they are THE bargain suspension upgrade for R33/34 GTR. they are around $2500 new so are by no means a 'cheap' shock and are made in japan. They are also damper adjustable.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
