Hi all, when in low rpm (usually after changing gears) i get really bad gearbox vibration, i have to rev past 3k (in first gear) so when i engage the next gear it doesnt vibrate, which you can understand makes baby jesus cry in the morning when the car is cold. it does this with all gears if the rpm is low enough, but as the gears raise the vibration is easier to avoid since raising the rpm to change gears isnt as painfull.
the vibration goes away shortly as i raise the rpm but it is quite bad and even loud through the car.
ive had the same issues with previous skylines, but the vibration was easier to avoid and you didnt have to rev as high to avoid vibration in the next gear.
any ideas what it could be?
Edited by Clutch
https://www.sau.com.au/forums/topic/351634-gearbox-vibration/
happened to me a couple of times, first time was sagged gearbox mount, changed the mount and it was fixed
second time wasn't that bad, it was due to the mechanic not alligning the drive shaft on the rear diff correctly when he reinstalled it after changing clutch. the shaft is balanced with the diff so it has to go back in the same way as it came out
while most people would say that drive shaft issue should only be speed dependent, i can confirm that the rattle was rev/load dependent, not speed
ok, at least they are 2 semi easy problems to look into.
which gb mount are you referring to?
and how are you supposed to know how to align the drive shaft? or can only a mechanic do this?
Tailshaft should be marked when removed so it can be installed back into the same spot
I guess the driveshaft can only go on 3 other ways but if it hasn't been taken off since it started doing this it's more likely to be another problem
The worn gb mount was a worn standard mount sitting right below the gearbox, there's only one
Changed to polyurethane and worked fine. New car now has an ok standard mount so never bothered to reuse the polyurethane mount
Drive shaft wise if it wasn't marked on disassembly, you'll just have to rotate it and drive around, if not fixed then come back and rotate it again to match the next hole
ok great, ill try a new mount. where can i buy new rubber for the mount?
for the driveshaft, do i just unbolt at the diff and rotate it there?
Edited by Clutch
you can get nismo transmission mount, stiffer yet not as harsh as polyurethane, plenty of places have them, justjap or even ebay..
a cheap/free way of doing this is to reuse the original transmission mount by squeezing oversized rubber hoses into the gap and cable tie it in, i've tried this on a couple of cars and it worked great, if you still have the standard transmission mount it would've been pretty worn by now, so even if this wasn't the cause of problem it will become a problem sooner or later
rotating the driveshaft is just like what you've said, unbolt at the diff end and rotate it from there, there are 4 bolts, but make sure you mark it before you do anything in case that isn't the problem
if none of above fixes the problem, then its a worn centre bearing of the shaft which i dont think is serviceable.. means new driveshaft- unique autosports sell a one piece item which is reasonably priced
thanks mate your very helpful.
if the above 2 efforts dont work (which ill be trying soon) then i may try a new driveshaft, ive heard problems with the one piece driveshaft, are they that bad? whats the difference between 2 piece and 1 piece?
thanks again
edit, i tried searching for unique autosport, i only found the american based site, could you post their link?
Edited by Clutch
i'd try the gearbox mount first, this sounded like the exact same problem i had when my gb mount was worn
not sure about one piece shafts, as i've never used/ installed one before, so i can't really say anything based on personal experience.
one piece shafts are harder to install but it lacks the centre bearing so one less thing to fail, and transmits power more directly in theory.
there might be other downsides but i'm not sure, since i've never looked into this, maybe someone else can shed some light
unique has a few web addresses, one is www.nismo.com.au
Worn surfaces on the input cluster gears in the gearbox. I have this problem on my car. Replaced the mount with Nismo item gave me much nicer gear change feeling and faster changes BUT didn't fix the vibration issue - at all.
I've been told by a couple of gearbox places that it is the surface on the input cluster gears in the gearbox.
If this is the cause then you will not experience it in 4th gear, given it is a direct drive bypass of the cluster shaft. But yes, pitting on the gears can certainly cause vibration...more commonly it's a bearing issue thought, particularly when it's affected by load and engine speed. I daresay OP may have a worn input shaft bearing or spigot, which are both directly affected by engine speed regardless of gear you are in.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
