Thanks for your appreciation popinr33.
"B" and "P", thanks for your feedback on the Kakimoto.
I guess my dilemma is this...
Just a straight swap from the Nismo 3" to the Kakimoto 3.5" gives me this...
If the improvement, was just 3-4Kw, I'd just switch back to the Nismo exhaust which I'm quite happy with - even power-wise.
However, 13.4Kw is an appreciable and noticeable gain; so...
should one consider a Varex rear muffler, or perhaps wait for a 90mm HKS or equivalent.
Pls don't laugh, but I actually bought some ear plugs at the local chemist to-day (for temporary relief of course hehe) > proves I'm not going deaf just yet.
Terry, going by your photo's it looks like your version of the N1 is the PREMIUM model. That is rated at 98 Db (Who know's what RPM that Db rating is at. Proberbly when the starter motor is turning over) . HA! For starters it doesnt have a mid muffler (where as mine does) and the section after the catback is 90 mm (mine is 80). Would love to hear this thing on full noise! I'm sure it would sound just stupidly loud..... but oh so unreal level's of awsomeness at the same time!
Mega-N1 apparently, but I didn't know about "Premium" type "P"
There must be some sort of packing material inside that cannon - surely.
Yes it comes with a Restrictor/Silencer "B". I can see myself lined up with other cars at a Defect St'n and here's Terry ramming the silencer up its ass >_<
It looks as if it's never been fitted before - tight fit.
  • 1 month later...
Thanks Michael & ML73ZR...
I realise that ^ ^ ^ whilst apologising to wifie saying, "Guess what! Something else has come up!"
Yes, she's hard to let go of.
And it doesn't make it any easier knowing that many friends here on SAU would chop off their li'l finger for the above. > A deposit was accepted to-day!
Love that "flat" torque/power curve.
Pretty much pushing out ~300KW from ~5300rpm to redline.
Thanks Rhys and Matt.
Just got the car back from Unigroup Eng.
The above figure was the final rKw one after boost had been rolled back to 1.4bar with 98RON and -7 turbs.
I wanted boost to come on earlier - bottom end power: but only a little top end power was sacrificed due to Yavuz' superb tuning.
Thanks too to Steve-0 for working with Yavuz and getting Poncams and Tomei cam gears to suit. Cams advanced 3-4 degrees.
Thanks - yet I have Yavuz to thank for that. Steve-0 and Yavuz case-conferenced on what my car needed!
I'm aware that it takes a special skill to place the mass sensors correctly on the D-Jetro and tune accordingly.
I understand that the new owner Simon will eventually take the car there too & make sure that the replacement 044 fuel pump is operating well, unlike its predecessor (which was also brand new). Congrats to Simon!
so its gone,:blink: whats next???
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
