Hey guys,
when driving in 3rd gear, standing on the throttle at 60 does virtually nothing. At around 4k, the turbo is sitting on around 10psi. Once you come onto around 4800-5k, it hits 15psi hard (cant believe the difference in power between 10 and 15psi). Any ideas why it boosts so late? Has been like this since I changed the turbo but having looked through the dyno results pages - noticed that most turbos are on full boost by 3000, with the larger turbos around 3.5k. Any ideas?
Mods are as follows:
Nistune ECU
Standard Bottom End
Standard Head Minus Tighe 264 8.5 Cams with Adjustable Gears
Gt2876 with 12psi actuator bleed to 15psi
Stock Cooler and Piping
4" intake pipe to Standard AFM
Standard Manifold
Standard Dump Pipe with 3" Exhaust (Highflow cat and Cannon Only)
I can do a bit of a test drive with a video cam and post up the boost guage and tacho if needed or if it helps.
https://www.sau.com.au/forums/topic/352235-rb25-gt2876-15psi-at-4800/
  • Replies 47
first test would be to pull the vac line off the actuator and plug it up and see when you hit your target boost then, but make sure you back off straight away as with everything working it'll free boost.
I have done this accidently before - roughly the same boost pattern.
Thanks Captain
Found it on GCG, seems like another new name/combo, Garrett really are getting over the top!
What housings did you get with it?
Garrett Turbo: http://turbobygarret...6R_705330_2.htm
However, this was designed to go onto an sr manifold. So I took it back to MTQ and got a t3 housing - unsure of ratio. The turbo bolts to standard dump pipe so it may be a direct replacement rear housing for this turbo.No machining was needed to fit it to the turbo. I believe the compressor ratio was 0.86
Edited by Stargate
It will be the fact the 2876 has a cropped gt30 exhaust wheel, and the exhaust housing is to suit an uncropped wheel. MTQ should know better.
True?!
I always thought it was a 2871 GTRS with a 76mm front wheel... How sure are you that it is the cropped GT30 rear wheel?
If this was the case, we could use this CHRA to build 2835 variants. Simply have GCG redo it with a 71mm front wheel to make a 2835 spec CHRA or even build a GTX2835.
The only issue will be the exhaust housings, the OP6 would probably be the easiest way to go.
The GT2876R has a 53mm turbine wheel, same as the GT2860RS and GT2871R. It is a TERRIBLE mismatch of turbine to compressor. U get no more than the power of a GT2871 R but the lag of a GT3076R. Even garrett state on their web site that it's not for normal performance applications:
* Best suited for unique applications such as asymmetric turbo installations
* Not recommended for general performance applications
You're really gonna get HUGE gains from a GT2835 or GTX3071R or GT3076R. The GTX3071R would be my pick.
Edited by bradsm87
Yep, it'd be the same as the HKS 2540. That was completely replaced by the GTRS, same peak power with better spool.
Anyway, it's meant to be for small engines running big boost with a T25 footprint. This isn't the only problem as you would expect boost still well under 4000rpm with a 2876 on an RB25. You should get 1 bar around 3500rpm in 4th with a 3071, even lower with 2871 (GTRS).
Did you do the cams and turbo at the same time?
Check your timing and adjustable cam gears.
Timing is spot on with the gears set to 0.
I would really like to get the gtx3071r but since I am attempting to sell the vehicle, I dont really want to spend money on it. Not to mention changing manifolds, piping, exhaust etc.
Hmmm, well as mentioned it comes onto 15psi in second around 70km/h at roughly 4.5-4.8k revs. Breaks traction coming onto boost in first and second, but its very hard to launch (as you could imagine). Kinda fun to drive though.
Considering selling for 8k now, just so I can get my gtr. From what ive heard above, about $2-$3k worth of mods and it will go quite nicely. Shoot me offers via pm if interested...
Indeed this is why I asked about the turbo itself, I'd be very suspect about it.
Have the gate held shut and test it, but the likely scenario is as above.
ive had this turbo on the car for around 9 months so im sure any warranties (if any) are well and truely void. I suppose I could pull it off and get MTQ to check it out and fix it, but i'm sure it will cost me a few $$$.
Well it wont be under warranty if there is nothing wrong with it... Which there technically isn't by the sound of it
well,ive shot mtq sydney an email asking them is there is any option for a cropped t3 housing with the nissan 6 bolt dump. If not, what option(s) are avaliable for exhaust wheels to suit my housing.
I have tested this a few months ago, but will do again tonight just to confirm. No change in boost speed.
+1 for thinking there's something up with that turbo.
I had a genuine gt2876 with a .86 rear housing on an stock rb20 once and i was hitting 18psi just before 4500rpm, so an rb25 hitting full boost at 4800rpm with the same turbo doesn't sound right.
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
