White whale ready for tomorrow :D changed diff oil now, it was very shiny and had a couple of bits in it so hopefully it'll be better with fresh oil and stop peg legging!
Autobarn were the only people who had Motul FF LSD oil and it was hidden behind some other oil too.
Nope, still peg legging :( heaps.
Only got a 67 :( Which was rather embarrassing seeing as I got a 66 in Dan's 33 :P
New tyres are really good though, getting some good entry speeds, rear is pretty wild though. Maybe need a big wing to settle it down?
Or softer setting on the rear sway bar? softening the rear dampers helps too yes?
Just going off what I read on here
http://www.mcasuspension.com/setup.pdf
So, I've got the Nismo GT Pro LSD 2 way diff.
For future reference and if any one else needs to know about rebuilding a Nismo 2 way here are the two PDFs you'll need
http://www.nismo.co.jp/products/competition/lsd/pdf/lsdpro_price.pdf
http://www.nismo.co.jp/products/competition/lsd/pdf/repair04.pdf
Just putting them here for later :) of if anyone else needs to rebuild a Nismo two way diff.
it should be if it's a gt pro
http://www.nismo.co.jp/en/products/competition/lsd/gt_lsdpro.html
if you pop the shafts out, there will be a 19mm hex head under one of them. You have the option of 3 settings soft med and hard
I didn't install it so I've got nfi, I'll pop the shafts off this weekend and scout it out.
I'm thinking rebuild might be required though because when I dropped the oil out lots of bits came out, looks like some one's put a fist full of 5c pieces in a blender.
New fiber glass guards should contain my wheels nicely.
Edit:
And here is a pic of all the bit o diff that came out. Prolly heaps more in there.
Edited by zoidbergmerc
  • 4 weeks later...
New Cazman adjustable Camber, Traction and Toe arms.
Installed.
Installing them was easier than sitting down, one hint though, to remove the Traction arm, you need to have the camber arm out of the way. I only noticed this after I'd installed the camber arm and had it all torqued up.
  • 4 weeks later...
Got my Diff rebuilt, biiiiig shout out to Martin at Tas Mobile Mech for getting it done for me! Also to Dave.TAS for helping source the parts!
Here is the old vs new shot
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm, not good!
Fresh Diff felt amazing though and I managed to rip some pretty good skids on Saturday at the Time attack.
I think the 3rd one is my Fav :D Might have to get a print and hang it up at work to remind me why I go there every day.
Results from the day were, 6th in Drift and 2nd in Time attack (Race Class)
Casualties were, another radiator hose and the loom that goes up in the front guard so now non of my accessories work :( Managed to test the endurance of my car though, lasted a whole Time attack session, like 30 mins easy, water temp didn't get above 90 :) I was doing like 2 hot laps and 4 cool down laps then two hot laps, ect ect.
It was a really special day, I just wish more skylines were there to share the experience :) Next time though! all you assholes have to come play too!
your front bar nearly lasted the whole day to :whistling: jokes aside you and the car did really well :thumbsup:
Hahah yeah that front bar Copped it hard!
Cheers man :)
Here is a pic of me not going sideways, a rare sight I know.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
