So the other week i stupidly let one of my friends drive my car. Hes revved it a bit (alot) to high and i could notice he was slipping the clutch abit. Anyway around the next corner hes pulled over and said that none of the gears are going anywhere. So i hop in and put it in 1st, let the clutch out nothing, 2nd nothing. Sure enough no gear grabs at all.
I keep trying and then notice that in first gear the car will roll at about 10kph but revving it just revs the engine with no forward movement. So after spending the last hour reading various pages on this forum im getting very worried about it being the gearbox. Instinct is telling me its the clutch slipping. But the fact that it suddenly wont grab at all, and hasnt slowly deteriorated has me worried its not.
So is it the clutch or worse... the gearbox? What do you gus think?
https://www.sau.com.au/forums/topic/353145-clutch-or-gearbox/
If you're not hearing any strange noises coming from the gearbox when the engine free revs in gear, it's most likely clutch slipping.
Have you got a fully functioning 4th gear? If so, then he's blown the layshaft in the gearbox. If not, then I'd say he most likely burnt the clutch and it's now slipping. Clutch contact plates don't go from grip to slip as gradually as you might think...particularly in turbo cars. A worn contact plate will feel the same as new. Your clutch might have been badly worn and his bad driving pushed it over the edge. If it's a button clutch, these don't respond well to slipping and can burn out in a couple thousand km when driven incorrectly. Another possibility is a snapped input shaft, but it's unlikely.
Yeah pull the box out and have a look. As said above when they start going they go pretty quick. My stock clutch continued to get worse when I drove like a grandma to conserve it, if your mate was thrashing it then for sure it could have gone much quicker
Don't let people drive it unless you know there not gonna treat it like shit ;)
Hey Mate sounds like clutch to me, if it was the gearbox it would have made a hell of a noise if you broke a lay shaft or input. How old is the car/clutch, is it a standard clutch and how much power does your car make, clutches don't last for ever especially if its a standards one in a boosted up ride, i would definitely be looking at the clutch.
clutch toasted. as long as you are not feeling anything weird when selecting gears etc, or noises when you free rev (with car in gear and foot off the clutch pedal) then it's 90% sure to be clutch. if your mate was revving the crap out of the car and had his foot still on the clutch pedal then he was overheating the clutch and has probably damaged it. at this point it doesn't matter too much as regardless of whether it's box or clutch the gearbox has to come out to diagnose/replace whichever is broken. I'm going to go with clutch though.
Hey guys thought id post here rather than start a new thread as my problem is similar, what i have is a mild crunch into fourth gear, if I synchronize it ( double clutch ) its good is this gearbox? I would think so but better to ask some people with more extensive knowledgew of hydraulic clutches etc as my experience is 100% cable style
Thanks
Thanks
I would say its a worn out synchro. My car did the same once the gearbox oil was hot. I recently had the gearbox out of it, so threw in a fresh synchro on 3rd ond 4th and now it drives as good as new!!
im gettng my clutch done soon, while the gearbox is out, how much would it cost for some new synchros?i
Well I cant say specifically about your vehicle. Mine cost about $1700. New front diff oil and gearbox oil, new synchro's on 3rd and 4th, new spigot bush/bearing and labour.
unfortunately your in perth so you'll pay through the nose.. cost me $1100 here just to get a box inspected, rang 3 other workshops here and they thought that was about right :rant:
now I pay the $100 each way and send them to Competition Gearboxes, Croydon Vic.. Simon top guy to deal with. I had quite a bit of work done and sent him a few boxes. but from memory I think he said about $800 for syncros, bearings etc
ring around locally and then give him a call, Simon--(03)97233380
$100.. who did you use for freighting? Lots cheaper than what I have been looking at..
yeah we have a Star Track Express account at work, but I think Simon at Comp. Gearboxes freights a few boxes around and therefore can get a good rate? worth asking whatever shop you are looking at using, they can normally get it cheaper than you..
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
