I just got a new Nismo GT LSD installed yesterday and they said to drive it slow for 3-500kms to wear it in. I also was expecting some chattering which i got, but heres the thing. Sometimes/often when driving corners slow or at low speed the thing really thumps i can feel it grabbing and then that force is released and i get some fairly loud thumps. When driving straight its fine and its makes some noise at, say, 40-50kph light cornering. So, this being my first LSD< im wondering
1, is this normal?
2, Will it get less violent over time?
3, Will the noise reduce when it get the NISMO oil changed into it after the run in period (like the bottle says)
4, What were your experiences running in an LSD
thanks
  • Like 1
Did you set it on it's soft setting or leave it on it's 'out of the box' medium setting?
Also if you used the Veruspeed oil that 'should' come with it, it has no friction modifier in it so you may need to stop in to your local performance supplier like rocket industries, performance wholesale or other places like that to pick up a bottle of redline friction modifier. This will help to quieten it down.
I see on pt3 what you said about the oil but it should get the Nismo oil straight out of the box.
It will become less agressive over time but if it's truly annoying, you can adjust the centre from the R/R half shaft. Just drop the R/R (right rear)driveshaft where it meets the half shaft and put your socket (17 or 19mm from memory) into the hole and turn it anti clockwise. That will put it onto it's light setting.
Also, if you didn't do figure 8's in a carpark or whatever for a half hour, it probably hasn't bed in completely yet either
Thanks for the comments so far, and any more suggestions or experience is much appreciated
it came with the Nismo oil but, on advice at the shop, I had them put in Wakos cheaper oil for the bed in stage and then after 500kms they will put in the nismo stuff. Apparently the nismo stuff is meant to have an additive in it that quiets the chattereing, but is this what im experiencing...?
I know that the more expensive GT-PRO LSD has a way to adjust it, but i have the normal non adjust type.
I havent done figure 8s in a car park yet due to no time and very few car park areas to do it (Japan!) but im hoping that just driving it with care, not thrashing it etc will get the job done over time.
I notice the nismo page says( The design standard for the initial torque output value is 8.0 kgf·m at the time of delivery. After the LSD is broken in and the plates are working well together, it will stabilize at 6.0 to 6.5 kgf·m. ) I guess this means it should calm down a little over time?
The diff is 1.5 way, but im just still a bit surprised. Put it this way, its not an annoying sound so much as its a noise that has me a little worried, like it feels like its not quite right, i wince a little sometimes on the slow cornereing. hmmmm
It's normal.
Do the figure 8's. The chatter you are experiencing will quieten down considerably.
Without doing this (as instructed in the Nismo instructions) you will not bed it in correctly. Nismo is a Japanese company, surely they found a place to do figure 8's. Try ringing them to ask where :P
yeah it's normal mate. a tight mech LSD (regardless of 1way, 1.5way or 2way) will give you some nasty noises and bumps and chattering when new and tight and can do even for a long long time. when doing tight slow turns it may feel like the arse end is about to fall out of your car but believe me it's fine. I'm sure the workshop in japan you are using knows what a new LSD is like so if you are really worried get them to drive but my bet is it's completely normal. the reason is they lock up under the slightest throttle application so at low speed tight turns you have one wheel needing to travel a shorter distance than the other but as they are effectively locked together by the diff you either get some tyre chirping (wheel slips on the surface) or the diff locking and unlocking providing the chatter/shudder.
The Nismo diff is noisy irrespective of which setting you have it on. The lowest setting is alot less nasty than the tightest, however. I found that using something other than the fluid provided with the diff does quieten it down a little.
It's normal.
both right and wrong dan :P
nismo reccomend driving in the hills to bed it in, it's the KAAZ diffs that tell you to do the fig 8's ;)
remember to do them in first gear and to have the clutch in on the turns
refer to kaaz website with diagram HERE
i did this procedure and my nismo diff is perfect and has been for years now.
fwiw i change the diff oil with my engine oil (so every 5000 or trackday interval) with motul gear competition 75w150 and it quietens it down every time
It's normal.
lol!
If you do...post the recording of the call
Incorrect regarding nismo run in
Nismo State the following
"After Installation, test drive the vehicle for about 180miles (300km) at speed less than 40mph (60kmh). Avoid any quick maneuvers"
http://www.nismo.co.jp/en/products/competition/manual/pdf/lsdpro_manual02.pdf
Regardless of what they suggest, it is still correct to run a diff in by doing figure 8's
this.
my guess is that nismo probably think they have more chance of getting people to actually use their method
I ran it in with 30 mins of figure 8s. man, thats boring. It seemed kinda quieter after that time, as in i could do 8s with almost no chatter, but on normal driving it was still there. I think ultimately its normal and just what i gotta live with
Wait till you drive it in the rain and it understeers into the curb at speed.
Then you will hear all sorts of noises.
I pulled the 2way out of my car due to the lack of turn in it gave it.
A locker is awesome on a really stiff car like a v8 supercar, notice how they jack there wheels to unload one back wheel
Driving it on the street is a major pain in the arse
your joking right?
I had zero issue with turn in with my nismo 2way lsd in my r33 gts-t, my old man even drove it and had little issue with it.
And regarding the noise issue, Was your install setup correctly? (i mean when it was install in the housing, eg correct backlash etc)
I bought myself a brand new nismo 2way lsd (normal GT type, non-adjustable) install in the housing by a pro, ran the lsd as nismo stated change the oil after the running 300-500km (using the nismo/motul oil) and mine was not very noises at all i was very happy with it
  • 1 year later...
For anyone still reading this, I found Nismo oil to be the best for quietness. It appears to have been made with motul, but in Aus I put in the motul brand oil in and although it chattered less than cheap oil, I will be soon ordering the Redline friction modifier to see if that helps me more, as its still a little too noisy for my liking.
  • Like 1
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
