Ive got a permacool oil filter relocater kit with an oil cooler in line with it. anyway the lines, filter and fittings all get quite hot.. and you can feel the pressure going thro the lines no worries. esp the ones too and from the oil cooler. However the oil cooler itself is stone cold to touch. even after a few hard laps at the track when oil temps go to 110 degrees its still cold. yet i have oil going too and from it.
wtf?
https://www.sau.com.au/forums/topic/353887-oil-cooler-question-its-cold/
If the oil cooler is damaged why would it make a difference which side of the filter its on ?
I'd have thought filter first because if you lose an engine the shrapnel shouldn't get past the filter and get caught in the cooler core , one less thing to replace with the rebuild .
A .
Is there a thermostat in there somewhere? If not it shouldn't matter which way it's hooked up, it'll still flow in the configuration you have.
The horror stories are from ones with the 2in-2out style oil filter relocator/thermostat in one types (hks/trust).
Anyway, you've said the lines and fittings up to the core are hot and you can feel the pressure in there so there must be some flow through the thing, or your engine would already be dead from lack of oil.
You don't have an inline thermostat hidden in the guard somewhere that you have forgotten about do you?
Can you feel a difference in the lines going into the cooler and coming out? If the line coming out is cooler then the radiator is doing its job. According to Earls you should filter the oil before it goes through the cooler. Will try to upload diagram.
A .
exactly it makes no difference. and you should always send the oil through the filter first, then the core, then back to the engine. set-ups with the thermostat built into the filter head do exactly that. when cold oil travels from engine, to filter and back to engine, when hot it goes engine to filter to cooler then back to engine.
as it turns out i mistakingly hooked up the outlet on the block sandwish plate on the centre of the oil filter... and from there it was looped thro the oil cooler.
swapped these two lines around on the oil filter attachment and then ran it and within a few mins the oil cooler had warmed right up... so now its flowing as it should.
hope no damage has been done :( :S
That sounds like what was done to mine. After a few power runs at 8000+rpm and 475rwkw we checked to see how hot the cooler was.... It was cold. :O
We drained some oil out and it was full of metal.
Towed car away, had engine pulled out, found the bent crank. Now just waiting to get it rebuild again.
If only I had my tuner fit the engine instead of another local so called "mechanic"
yeah I can't imagine your engine will be alive. if the cooler was plumbed up so nothing was flowing through it (i'm not sure how btw?) then that means oil was coming out of the filter head area and then going no-where. but if you just have one 'out' hose and one 'in' coming off the engine filter head adapter then it shouldn't matter which way you connect them to the cooler.
oh wait, i see. you hooked the engine 'output' line to the remote filter 'output' instead of the filter 'input'. you could be in trouble, might get away with it. but if the engine is still running then that's a pretty fair sign it will be ok.
Would most likely have popped through the oil filters drain back valve too as if oil was being fed through the filter the wrong way the rubber flap that stops oil draining out would been stopping flow but I guess eventually it just would have forced it's way through.
oil analysis, its like $50 and mainlube.com.au do them, highly recommended, will tell you if you have shagged the bearings or anything.
this is something you want to find out now before catastrophic failure, it could be fine though.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
