Import Monster Sauvic Deca Motorkhana - 2011 Round 1
Whatcha entering Juz?
My new Nascar Pedal Car... It's pretty quick, depending on how fast you can pedal and I can pedal really well, its also a good way of keeping fit. Hopefully get some good results! :D
Heres a pic...
So this one is the daily and the Impala car is the weekend car ya?
The impala is not road registered just a track car...
And how did you know that was my daily? Have you been stalking my garage!
I have a fax that has failed to come through...
NUMBER : 03 9200 46**
P.S I will be updating the list tonight...
P.P.S EVERYONE - FILL IN FORMS COMPLETELY
Faxed!
Lets hope my clutch holds up longer than 2 runs :-D
Good work rosco! she will be fine!
FARK thats my fax LOL
what was wrong with it? Said it was fine from my end
thats cos u succesfully sent through 2 blank pages ya goose...
I have it on good authority there is about 10 spots left so if you are one of those 'ive paid and ill fax in a few days' ppl, then i suggest faxing very soon. (we dont care if you have paid at this stage, we just want forms FILLED OUT CORRECTLY AND SIGNED CORRECTLY). then pay ;)
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
