FS - Starcorp Impuls 18 x 9.5 18 x 8.5 +38mm sit just in from guards on a 33 gtst, minor gutter rash on all 4 nothing too serious. bit of paint fade in centres, brand new yokohama tyres on all 4 only put on last week. asking 1100 ONO.
PMs only please
fibreglass bonnet in black for R33 GTST these go for over a grand new...
asking 600
willing to swap plus cash my way for a standard gtst bonnet, prefer black.
Hi Guys
Up for sale are original R34 GTR wheels , they are immaculate inside and out .
There is one scratch 2 cm wide on one wheel hardly noticeable but otherwise perfect they have 265/45/18 Ventus Hankook RS-3s
Rare tyres in Australia Amazing grip with 70% tread with next to no camber wear .
Looking at $1800 due to there perfect condition
Click on pics to enlarge
They are currently in Belair South Australia 5052 can Freight anywhere in Australia for added cost .
Thanks .
Mark
F.S.
Splitfire coilpacks to suit rb26/rb20 and series 1 rb25 $400
2x R34 N1 turbos (2860-7's), one is fine but the other needs to be rebuilt with new bearings $600
Turbosmart boost T $50
Delphi 1000cc injectors to suit rb26/rb20, they are low independence and straight bolt in. Brand new in the packets $500
0433943034
For sale
Sa
Brand new smoked/clear r32 gtst front indicators.
I do have all 4 chrome bulbs but I think the fitting is wrong, orange bulbs available too.
Never fitted, can post at buyers expense.
$150
PMs only please
asking 600
still for sale
bonnet still for sale too
got some r33 nismo clear side indicators for sale too PM with an offer
parts im after if wanting to swap or make a deal or whatever
r33 s1 bonnet
stock wheels (2 or 4) or meshies
400r rear bar
standard side skirts (2 door )
m spec front bar
rb25 turbo
z32 afm
gearknob
or any rb25/r33 parts
cheers
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play and ready to bolt straight up to your GTS-T.
Includes turbo itself, elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$900 ono. Pickup from 5098.
z tune r34 gtr body kit,seat cover,interior carbon fiber bits $3000
hi,i have r34 z tune front bar,side skirts,rear pods and front undertray,superior seat covers ,carbon fiber bits as per photos .if interested please contact me on 0478104724 and am selling as a lot .thanks
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
