FS - Starcorp Impuls 18 x 9.5 18 x 8.5 +38mm sit just in from guards on a 33 gtst, minor gutter rash on all 4 nothing too serious. bit of paint fade in centres, brand new yokohama tyres on all 4 only put on last week. asking 1100 ONO.
PMs only please
fibreglass bonnet in black for R33 GTST these go for over a grand new...
asking 600
willing to swap plus cash my way for a standard gtst bonnet, prefer black.
Hi Guys
Up for sale are original R34 GTR wheels , they are immaculate inside and out .
There is one scratch 2 cm wide on one wheel hardly noticeable but otherwise perfect they have 265/45/18 Ventus Hankook RS-3s
Rare tyres in Australia Amazing grip with 70% tread with next to no camber wear .
Looking at $1800 due to there perfect condition
Click on pics to enlarge
They are currently in Belair South Australia 5052 can Freight anywhere in Australia for added cost .
Thanks .
Mark
F.S.
Splitfire coilpacks to suit rb26/rb20 and series 1 rb25 $400
2x R34 N1 turbos (2860-7's), one is fine but the other needs to be rebuilt with new bearings $600
Turbosmart boost T $50
Delphi 1000cc injectors to suit rb26/rb20, they are low independence and straight bolt in. Brand new in the packets $500
0433943034
For sale
Sa
Brand new smoked/clear r32 gtst front indicators.
I do have all 4 chrome bulbs but I think the fitting is wrong, orange bulbs available too.
Never fitted, can post at buyers expense.
$150
PMs only please
asking 600
still for sale
bonnet still for sale too
got some r33 nismo clear side indicators for sale too PM with an offer
parts im after if wanting to swap or make a deal or whatever
r33 s1 bonnet
stock wheels (2 or 4) or meshies
400r rear bar
standard side skirts (2 door )
m spec front bar
rb25 turbo
z32 afm
gearknob
or any rb25/r33 parts
cheers
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play and ready to bolt straight up to your GTS-T.
Includes turbo itself, elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$900 ono. Pickup from 5098.
z tune r34 gtr body kit,seat cover,interior carbon fiber bits $3000
hi,i have r34 z tune front bar,side skirts,rear pods and front undertray,superior seat covers ,carbon fiber bits as per photos .if interested please contact me on 0478104724 and am selling as a lot .thanks
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
