i dont know if this is that cheap, i havent looked into this size before, but there is a joint near my work here that has these tires for that cheap, they are probably a cheapo brand, but if you dont care about brands like me then awesome.
at the end of hatnette drive in seaford
Edited by ClutchBurndout-:(
https://www.sau.com.au/forums/topic/357838-cheap-tires/
Jamie I believe Ash is using the "yum cha" reference to suggest these tyres are cheap inferior, dangerous shithouse tyres.... Much like cheap chinese made imitation brand car parts! :laugh:
Yeah I know man, hence the ':P'
https://www.sau.com.au/forums/topic/357838-cheap-tires/#findComment-5719677
If theyre that cheap they are probably crap quality, but if you are happy with them then go for it.
From what I remember seeing Bob Jane had some Kuhmo's in that size for around $50 more, if you shopp around you may be able to get a decent brand for a cheap price.
https://www.sau.com.au/forums/topic/357838-cheap-tires/#findComment-5723494
Sorry 139 each!which included balancing and fitting!Thought that was pretty good! I could have got tyres of an unknown brand for under 100 each but f**k that, unless you want to be buying more a few months down the line or pulling your car out a ditch!lol
https://www.sau.com.au/forums/topic/357838-cheap-tires/#findComment-5724071
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
