finally after getting the wrong coloured facia its all back together and I have a radio again!!!
I've put up a thread with the wiring colour codes in case anyone else needs to replace theirs, cant seem to link if for some reason though.....
Http://www.skylinesaustralia.com.forums/topic/437160-m35mradio-replacement-wiring-colour-codes/
Finally got my go-pro footage from the SAU track day back on the 29th of Oct 2013 @ SMSP south circuit.
here was my last run where I got a free run with no traffic and managed 3 awesome laps
2x 1:09's and a 1:10.
http://www.youtube.com/watch?v=dcvL4eyt1qY
best of the day was a 1:09.14 with consistent 1:09's all day long :)
starting to get p*ssed off with all the little niggly bits, so I'm going to try and sort them out before I loos my sh*t:
1) redo my headlights
2) need to get the bonnet struts as the fibreglass bonnet is to flimsy to support by the stock arm and so the AXIS bonnet add on is starting to fall off.
3) this radio change over has been a massive PITA, hate the aftermarket A/C buttons, and seems as though I've blown part of the BCM that controls interior lights, tail lights and parker lights so now I need to replace the BCM which seems more or a PITA than it should be.
4) need to tidy up my gauges as it looks like sh*t so going to have to pull my finger out and make a fibreglass one!!!
5) should probably replace my drive belts and fuel filter I'm guessing they are well over due!!!
6) need to get this window washer bottle cos its a PITA having a dirty window all the time that I cant clean whilst I'm out
once all this is done I might feel better cos atm I'm getting annoyed my cars turning to sh*t because of neglect!!!
ah well that's my rant for the week!!! :)
I still have no 6 in pieces. :domokun:
I'll get cracking.
You makin a washer bottle Dale?
I did a cardboard mock up about a billion years ago for Theo; will use the OEM filler neck, and the side also acts an air guide for his oil cooler.
I have all the sheet guillotined and bent, neck made, then we had another kid. :rolleyes: I need to machine some bosses for the pumps to push through then get off my arse & weld it.
I'm so busy at work now, I barely get time to do my paperwork in the extra hour I work on top of my 12hr shift. Weekends used to be fab time; not anymore.
It might hold a litre of water, with the neck volume added; a little more.
It's something I was interested to make for myself, sounds way too complicated to make multiples of though.
I would love to get a second oil cooler in there... Not like you need 40L of washer fluid anyway. :P
I have the advantage of being able to use my cardboard mock up for templates; I'll see what this one turns out like.
A litre odd would last long enough.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
