Can you please try them for just a 19 row core posted to NZ (should be much the same price as Australia) ? I can pay you or them direct whatever suits.
  • Replies 334
Posted Images
Yeah. See what HEL say about the relocator, keen to hear.
Ok regarding the relocater. They have looked into getting a Mocal relocater as part of the kit a little while ago and never heard back from Mocal. So they will suss it out again and get back to me. Might be an option for a seperate group buy later if it will be a while off. Anyway i'll update on this as I find out more.
i'll grab a 19row kit phil.
doing the rb20/30 oil block is the way to go. for extra sensors just use a brass adaptor where the factory sensor is.
Ah yeah didn't really think about using an adaptor of some sorts. Good idea. (Not that I currently need the extra sensors, but others do). Added to the list man.
Thanks, missed the 80degrees comment watching Erics wakefield vids :) A good temp, those at 60 are just too low.
Looing forward to the DIY, and will hopefully fit the larger one as well.
Yeah I was quite happy at the 80 degrees. Exactly like you said, the ones around that 60 degre mark aren't really best suited for a street car. Also added to the list.
I'll see what I can do. Perhaps if the relocater kits get done seperately, we can do like a mix and match parts list aswell or something. I'll update on this aswell.
Bah! Put me down for one, I'll find the money somehow :P
19 row or a 25 row? :)
Very interested in an oil filter relocator aswell. :yes:
Yeah I think I might go one aswell. The stock position really is a pain in the ass, especially with a big Plazmaman plenum in the way.
Called into the local stockist (Alert Engineering) to price the 19 row Seatrab - around NZ$500 incl tax!!! They used to stock Mocal as well but he claims that they are now Chinese manufactured and not up to scratch!? BTW he also recommends 25row for 300kw up.
WhiteR33GTS-T said on the first page that he wanted everything but the core. Perhaps chat with him and organise something with you two getting one kit and splitting it between you two.
No idea about some Mocal parts being Chinese manufactured. Wouldn't suprise me though, what isn't made in China? There is a difference with a company getting something manufactured in China (like 99% of companies) and a Chinese company manufacturing parts.
EDIT: Just did a quick Google search and found that in house engineering, design and manufacturing gets done at Mocal's premises at Isleworth UK. So no idea about the China reference. Perhaps only some parts are made there.
So is the relocator just for convenience only? Also were you able to confirm how long the lines will be? I'm planning on mounting it on the passenger side at the front.
Also with the stock cooler plate that the water coolant runs through, i thought i read somewhere it was to also help bring the oil up to temperature when cold, or is this incorrect?
Yep relocater is just for convenience only.
Lines will be 2m. Passenger side duct is probably the only place that 2m might not be enough so if you want more lines let me know and I can see if your kit can get a bit more (possibly at a small cost, maybe $10-$20).
Yeah stock cooler plate also warms the oil up a bit when completely cold by using coolant. This is because coolant warms up at a quicker rate than the oil. I suppose this is one of those things every one can personally decide on if they want to get rid of it. Since I live in a hot climate for me it isn't a concern and hence I will be removing the whole thing.
cant believe im only seeing this now.... Im in :) that makes it 10 too I think :)
I guess ill go the 19row as 25 will be overkill for a fairly standard rb25 thats tracked every couple of months... right?
Yeah 19 row will be fine.
Most Japanese oil cooler cores are a lot smaller than these things and a lot of cars run them.
Addded to the list.
There really is no maximum numbers for the group buy since they are all getting sent out individually, but I think I might cap it at 15 at this stage so we can get the ball rolling.
If the total length is 2m i'll measure up over the weekend and get back to you. Do you think there would be a downside to running longer lines? Just wondering if there is a reason they only supply 2m.
Just means you will put a little bit more oil in.
I guess because most people install them on the drivers side or in the middle so 2m is usually enough and doesn't mean you have heaps of extra lines going every where.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
