Booking in a track day, How long do you think they will take to arrive? If its going to be a couple weeks i might have to go easy at the track, booooooooooooo >_<
Wouldn't worry about taking it easy too much. If you are worried make sure you have fresh oil before you hit the track, then change your oil when you get home. If you are really paranoid have a cool down lap every 3 laps or so. Also keep an eye on your water temp / oil temp / oil pressure.
These are all things I don't do :laugh:
  • Replies 334
Posted Images
hmm just checking the calender i would need it before easter so i can fit it over the weekend. That's abit unrealistic for payment and transit times.
lol Matt I know what you mean it's hard not to get carried away and forget to watch the temps. I think the oil is pretty fresh i changed it after the sump plug group buy and only use the car on weekends. I'll just bleed the brakes and it should be good to go. If it startes heating up i'll do a cool down every 3 hot laps.
Righteo I had to change two people over as I have not heard back from the original two regarding payment.
Just waiting for the last three payments to come through and then we should be good to go to transfer the money this weekend :)
I sent through the order today and will transfer the money once I get final payment. He said he will start getting the kits ready today and shouldn't be longer than 1-2 weeks to get them all done and sent.
Unfortunately not. No sandwich plates with a thermostat do (didn't actually know that until this group buy) because there is simply no room for them.
However where the factory pressure sensor is on the factory oil cooler/warmer, you could remove that and put in an adaptor so you can run two things.
The other option is to get a filter relocation kit and run it from that.
Man that sucks, (besides the obvious) what happened?
I was at the start of a 25kph road-work zone, trafic stopped at the lights in front of me. I slowed to a stop.
I look back in my rear-view, and a car is quite a ways back but still doing the speed limit (60kph) .. I watch him pass what I perceived as the braking point - and kept going, I knew he was going to hit me, hard. Right before he hit, I heard a squeal of brakes and slam.
Based on what the assessor has said, it's repairable. A good thing, since I only just fitted the 18" LMGT4s 2 weeks ago.. Now to get it off to the right repairer to take care of it.
Fark, I hope he's done for neg driving etc etc. That's bloody stupid.
Also, I'm hoping that even though you saw it coming, you didn't brace correctly and are suffering whiplash
stupid prick shouldn't be driving.
Just got told from Hel about a new product they have for their 19 row oil coolers (unfortunately got told a little to late for this group buy). It's an oil cooler air duct as seen below:
Basically allows you to route cold air directly into the oil cooler via some tubing.
Good for people that want to mount it somewhere where there isn't a great deal of airflow.
Anyway just thought I would show you guys in case any one wanted one. Will most likely do another batch of these oil coolers so if some one wanted one of these they can.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
