  • Replies 45
if you want to spend abit of money then get some quality jap rims for sure,
if you have a limited budget then get a set of rotas, they look quite good and are very affordable.
but make sure you get rims that have a nice offset with +20 being the absoulute maximum, anything around +12,+15 is desireable
If you budget is 2k, I would look at the Work Wheels. I custom ordered a set of Matt Black XT7's for our Midnight Purple R33 GTSt Project Car.
I have the R34 GTR wheels on now and love that look (and you don't need any spacers)
hes asking about a gtr, not a gtst. 34 gtr wheels are +30 so would definitely need spacers to get good fitment
Understand that, however it depends on your definition of "good fitment".
R34 is 18 x 9 +30 and R33 is 17 x 9 +30, so depending on the intended use of the car, a set with a "less aggressive" offset might still fit his needs?
stock wheels sit waaaay too far in the guards imo, plus if hes running coilovers, he might have issues clearing struts. i know i do with my standard wheels, need to use 5mm slip ons
plus gtr wheels are overpriced imo considering their width and offset. my advice if youre on a budget would be to go to http://www.option1ga...u/NewWheels.htm and buy some 18x10 +15 rotas for $1090
thats what i meant, the stock wheels sit way to far in for my liking, i wanted to use spacers to bring the wheels flush with the guard,
i think ill just go with a set of rota's. either 18 or 19's
hey guys this what i have decided to go with?
do you think silver as pictured or gunmetal with polished lip?
can anyone photoshop the centers gunmetal
Look like techs in 18x9.5 + 20
Had a set on my gtr before i put the gtc's on. Good bang for buck.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
