This engine is 105kgs lighter than the VG30DETT, much lighter rotating mass too. For example the cams are about .5kg lighter each.
Valves are around 2mm bigger reach and has four bolt mains. 93mm bore instead of 86mm
We decided to do this conversion as the VQ is a much more advanced and lighter motor
VQ30 Motor
Fitting motor and checking angles and measurements.
GT28RS turbos with Tial stainless turbine housing mounted east-west rear in engine bay.
Jigging turbos for 6Boost to make custom manifolds.
Custom Manifolds from 6Boost
GTRS Turbo set up with custom manifolds made by 6 BOOST,custom top feed fuel rail, stainless Tial V Band turbine housing.
Dry sump pulley and belt with light weight Kevlar -12 fittings and hoses. 1000psi rated.
Totally striped engine bay, linnished excess welds, panel glue and brackets, then we painted it satin gloss.
New Alternator Bracket
There are more photos on our Motorsports page, Just click on the Project 300zx links.
Also visit us on Facebook
  • Replies 57
TOPIC APPROVED. can't wait to see more johnny. post up all your crazy idea and plans please!! this car is going to be great. the real question is WHEN DO I GET TO DRIVE IT??? don't be tight john. you know the beer baron can handle the zed. i've been a boat captain for years, started in juniors, lazers, tasers, flying ants and moved up to offshore yacht racing. so I think i'm ready for a bit boat like this one.
Yes I have done a lot of sailing to, doesn't qualify you though Rich. She will be a fast boat now. You will have to get in line, after me is John Boston then John Webb and John Bowe, who was here today for a good hour checking the car out. He was very impressed and wants a drive. THe John driven car!!!!!!!!!!Then there is Dave, a mechanic here who has done most of the work, although I think he drives about as good as you, Beer Bitch. Hopefully you won't fit in it either, which is my excuse for fats not to drive it, he he.
Nice work John!!! The slot car has come a long way since I last spoke to you.
Getting very serious now and love the front guards!!! Going to look like a JGTC car....
Keep the updates coming...
Jack
LATEST IMAGES
The Plug is finally finished for the front bar, Painted in 2pack Black. Ready to make the mould, then it will be made in Carbon fibre
This is where we got our design from.
Just installed the motor and Dave is wiring up the Haltech with military spec wires.
I Still dont see any teeth
Looking good John
A bit of bling for you, gold heat shield by DEI, it is supposed to reflect 90% of heat. With the turbo's right back and close to the firewall this should help a lot.
Motor going back in today, ye ha.
Like a rat with a gold tooth. Beat you to it Beer Baron.
http://www.nismo.com.au/images/DSCF0071_000.JPG
http://www.nismo.com.au/images/DSCF0070_000.JPG
so john, tell us more about the engine.
How much have you needed to do to turn it into a viable track engine, just forged internals and a few odds and ends or does the factory vq30 scrub up ok block wise and just needs much the same love as say an rb26 or similiar.
To put it shortly, do you have to spend a mint to make this engine really go?
i already gather that ini your instance your going whole hog.
Hey Mr UAS,,,more power isn't going to fix your problems,,,that "Slot Car" as you call it,,,is what I would call in Slot Car terms a flexicar.
This is your car:-
This is a real Slotcar:-
Cheers cardigan wearer
Neil.
Yes Neil it should give you a run next time we meet. No more power, about the same we suspect, just much lighter, by 105kg. Not big money at all using a stock VQ30DET $1500, then added strong valve springs, dry sump, custom plenum, top feed fuel rail and exhaust manifolds, so it should be efficient. Motor only cost $2000 and has four bolt main, hard annodised pistons, Molly coated skirts, 93mm bore compared to VG30DETT so shorter rods and 9 to 1 comp so should rev. On E85 and 20psi it should easily make an easy 400rwkw with the boost button on the straights. Compared to the VG the VQ has a much lighter rotating mass, the cams are all hollow with narrower lobes and wasted down and all four are about 2kg lighter, a fair bit, alloy buckets with metal shim 39 grams each compared to VG hydraulic 63 grams each, multiplied by 24 adds up to, the cam gears are about half the weight, crank pulley is much lighter although now has a Ross Racing custom balancer. Even the ignition coils are by about 35%. The block being alloy is the biggest weight saving.
The VQ has better port design and stock valves are around 2mm larger.
We do have a spare block with Darton Sleeve kit so can go up to 100mm bore and with VQ35DE crank we have can go 3.8 litre and will use forgies then and bigger turbo;s and make easy 500rwkw.
In addition the VQ30 has another improvement being crank and cam trigger rather than crank angle sensor. More pictures to come, engine and gearbox have just been put in
New dry carbon targa roofs ( no gelcoat, all carbon fibre, Kevlar, Polly core and epoxy resign), now 980 grams each compared to wet carbon 1.55kg previously, so over 1 kg saving off the roof.
Custom alternator bracket to support the rear of alternator, wasted down to save wieght.
Engine now installed into car with Turbos
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
