This is the footage from our new Go Pro Hero 3, we were only learning to use it but we are happy with the image quality considering it was through a wet plastic lense!
Go Pro Vid is a No Go. :(
I'm starting to wonder under what circumstances this thing actually has traction.
Idle? :D
Its up and going now mate! It was 1GB file lol
Notice at 1.33 you can see someones screamer pipe that has fallen off :blink:
Make sure you switch it to 1080 HD
So before all of these vids came the Friday and Friday night, once again another epic effort from JEM to get me to the event but also a quick thanks to DVS JEZ which was kind enough to let me break down in his workshop for a while lol
So, the ECU was picking up an issue again and i was pissed off, the same sort of issue as before and i was ready to give up. So we checked the front fuel filter at Jez's and although it was dirty it was not blocked, Jez luckily had stock on hand so a new filter was added and i was on my way again. (Queue skids and Gate)...
Everything was sweet for a while then 40mins into the trip it started leaning out again, This made me wonder as everytime the car would play up it would be after around 35-40mins... We tried to combat this with fuel cooler and bigger fuel system which certainly helped BUT there was an underlying issue we hadnt found. I limp the car to JEM while watching the AFR's like a hawk, they were not great but for light cruise they were doing no harm.
Once at JEM the guru (Adam) jumped in the car and we went for a run with the laptop, he noticed it was lean accross the board and immediately said it was the injectors, this worried me as there is no way the shit was getting through the Ryco filters and to the injectors... We took them in for a flow test (AGAIN) and the results were not good, they were all around 1200cc with shitty spray patterns, while speaking to the injector guru he mentioned they were down on flow from last time and when we checked the previous results we found they were 1300-1400 last time... At that time it clicked that these were meant to be 1000cc XSPURT injectors, WHY were they giving those readings?
So the call was made and as a result we found we had been supplied the incorrect injectors from the beggining, side by side with the 1000s they looked identical and no way i would have picked it but due to the part number they were identified as a troublesome 1600cc injector (I think based on the indy blue style) and from there things started to make sense.
The guys were brilliant as always and immediately started working on a solution to the problem, we were able to make the choice of any injector and as i plan to keep the 34 for many years and push it too its limits etc SO there was no point staying with 1000s when we had the chance to go bigger, although the bigger injectors were much harder to fit and also not as easy to tune (Dont want to make Adams life too easy) i opted for the big boy 2000cc injectors which Dean was kind enough to use the new ones waiting to go in his own personal car just to get me going...
It was getting late arvo and the injectors were finally in and wired up, I am sure it had been a long farking day for the guys but due to the fact i had Powercruise booked they were not going to give up.... The car was strapped to the dyno and the tuning was ready to begin...
By this time it was night and i honestly thought i was leaving the car at JEM and getting a train home BUT Adam re-assured me i was going to powercruise and that it would be fine... Due to having a full flex setup we could not do a full tune as we would have been there forever BUT a thrasher tune was chosen just to get me going and the fun part began...
After running the car up and being pretty happy with the results and the fact the car made the power so easily it was time to make the trip home.... Initial thoughts were FAAAAAAAARK as the car left on full power, felt so good to get nailed in the seat again and have the AFR perfect, it was a long cruise home after a little fun on the way to get fuel :ph34r: and i was home just after midnight.... 5hrs later i was back up and showered AND the car was driven to the track, the car made it and was faultless all day, the rain made it pretty boring but to be able to enjoy the car and thrash trouble free was quite a good feeling!
We had planned in removing the smaller stickers etc and just run the bigger ones BUT after the night we had i CBF and just ran the car in the filthy spec you see above.
Whats next? Well as the car still needs a full retune it will likely get a better dump pipe at this stage! As much as id love to accidentally slap a GTX3576 on it, i would just be pushing the internals harder than they need to be pushed, remembering i have a 100% stock headgasket and bottom end... :D
More to come soon -
DVS JEZ - Gauge fitment and wiring
Suspension - New balljoints, bushes and bearings
Interior - New Handbrake etc
Paint - repair boot paint and tidy up appearance.
OK, so my plan has been delayed by house renovations BUT i need to get the beast going again... When i lose momentum i tend to lose motivation, yet the second i drive it again i cant wait to do more SO the plan is to get it happening! First on the list above was gauges so i started this morning -
They are a perfect fit and sit in with no assistance at all but i will make a bracket behind them to be safe. Then ill get it on Jezs hoist and get the gauges done, i cant get to the Greddy block so i need it up in the air, plus i am useless with all things wiring related :P
wow. gauges are a perfect fit. what brand/model are they? its hard to read anything on their faces because of the flash/glare lol.
Just cheap stepper motor gauges, they are Racetech i think.... Basically Defi copies! There are two types, basic gauge and then these ones that have adjustable warning buzzers and peak reading recall etc.... The reason i chased these ones down is that they were blue with red needles to match the rest of the dash :yes: You can have them lit up white or blue, this was white with the power on -
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
