you mean you need one of these? ($210)
http://justjap.com/store/product.php?productid=18588
Vent holes/grill in the valley cover that allow air to flow can prevent the coils from cracking and the loom from going brittle.
That is exactly what i mean! You sir are a legend :thumbsup: you have saved me having to look any further :D
And yes i have removed the cover for now, vented sounds like the go... I still need to retain it to cover the coils and prevent the COZ RACECAR look as i am doing my best to stick with the stealth theme, i have seen the carbon vented items but these are of no interest.... I want something plain as always!
Loom will arrive tomorrow! Thanks Terry, appreciate the link!
No worries, btw I always chuckle when you write stealth with that shinny high mount ;)
Compare it to the 3 engine bays on the last page, its stealth enough :P
Went for a ride in this beast on sunday.
What a weapon. AWESOME street/track setup. I'd go as far to say it is the ultimate/perfect setup.
No Lag, Quiet idle/cruise, mental when the foot is down. Handling and brakes are great for the street. Love it. Well done Mat and the crew at Just Engine Management for a well sorted package.
Haha thanks Buddy, was good to catch up finally ;)
Hopefully once your weapon is ready we can go run amok more often like old time :yes: just much louder and faster now :P
why not buy a standard and add some vents to it yourself?
Also possible.... Can drill breather holes without any hassle, just the original plastic one looks pretty shit so was going to try pretty it up a bit :P The engine bay looks good but that cover always lets it down as no matter how many times you clean it or coat it black it just keeps ending up the faded plastic colour due to the heat i guess!
so prep it then coat it enamel! solved!
This sounds like it requires effort :/
Well actually it is off the car for a while so i should pull my finger out and do it haha
scotch brite it first then prep it with a few coats of under coat, then black enamel. Never fade again.
obviously cut it up and make it look cool before hand
Cost me $30 to get to work today.
If it doesn't get sorted tonight using ECU talk.
Then I am screwed! Been looking at some nice 34's
You mean mine? :P
Oh, and Just Jap dont muck around -
It was a GREAT catchup. Shame it couldnt have been longer. Im back late september. for two weeks (although one of those weeks I am in NZ), better catchup then?
Yeah, my nugget wont be ready for many months yet. Will be lucky to be end of year at this stage for run-in. But YES, we need to run amok again.
Im jealous, you seriously have the PERFECT streeter. What a weapon.
Edited by Tonba
Yours will be the same once its all setup and running! Will just be a bit more extreme in some ways :P
Yep, late September should be OK, we are away a bit and then October/November we are flat out!
It makes me smile everytime i drive it, thats all that matters too me man! If other people enjoy it then that is just a bonus haha
race your "perfect street" for slips? :P
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
