Shed could do with a pergola/awning imo, given how little depth it appears to have by those pics. You'd have to back it right against the back wall just to work in the engine bay without your ass hanging out in the sun :P
Otherwise this is shmexy as fuark.
This is actually something we will be looking into as we plan to complete the driveway and connect it to the main driveway, while doing this we will also have colourbond fences and a garden shed done, its quite possible we will do a carport style thing as we cant get the cruiser in either shed :P
Good stuffs :) if I had use of a shed such as that beast, I'd be looking for another Skyline/turbo'd performance car to get myself back in the game. Working on the 33 when it was either my daily driver or restricted to using off-level driveways f**king sucked hard....but if I avoid either of those, it's not all that bad really. Hell, it was almost a good thing working on it coz it kept me out of the fridge :P
Expensive hobby either way :/
But after all the time and money it does make me smile everytime i drive it, when Carmen does pics of it etc i look at it and think..... Not bad!! haha :D
Some new mods coming soon to get this thing reliable so i can start posting some actual reliable track footage haha
Loving the man shed there Mat!
Before you fill it up too much, get some insulation in the walls and ceiling; and sheet it. Doesn't have to be perfect, but it makes a difference!
Colourbond garages are either freezing cold or boiling hot; insulation is cheap. ;)
Thanks Dale...
Its pretty well shaded so i think summer should be OK, not sure about winter though!
I know the stuff you mean, ill get most of the stuff moved in anyway and see how it goes BUT if its an issue, like you say its cheap enough to do :D
Thanks Dale...
Lol, didn't mean to tell you what to do; I'd imagine insulating a shed is probably pretty low down the list of priorities...
It is nice though...
Pot belly stove in the corner for winter!
Don't plug all ya fridges in you dope, you'll just end up paying dorrahs to cool nothing! Also, it's cheaper to run a full fridge than almost empty, so use the freezer to store snags and steaks when you bulk buy :) man tips ;)
Also, silicon 90s are just fine, so long as you position them more than 3 cm from the glowing hot exhaust manifold or give them some protection :P
But I bet your solution will be top notch, they have been so far!
I agree, the silicone 90 on my outlet has been fine for 4 years and 6 track days, it's close to the manifold too. I would just make up a heat shield for it and see how it goes.
Yep good advice man! We will work out the best plan... And yeah bulk meat FTW!!! No homo!!! :ph34r:
Interesting! I dunno WTF my issue is then..... the second one lasted 4-5 laps and is GOOOOOOONE!!! And i made sure the best i could it was fitted right given the working conditions i had, even if it had a slight kink i cant see 20psi being enough to do this -
The old one lasted 2000km including a Texi event where it would have been red hot, so why did the new one last so little? They both split in different spots too! The pipes are smooth and there is no evidence of contact with anything! Fkn :wacko:
heat & ze boost ?
Yeah that seems to be the combo for fail BUT why are so many others managing to survive and mine hasnt?
Either way i will fix the problem good and proper BUT just want to make sure i am not missing anything obvious to make sure i get it fixed for good!
Hahaha lost my shit!!
Also just to throw my 2c in with the piping, I got told by Paul at pulse racing that hard pipes are generally a good idea due to the heat from the engine bay (and the boosted air to a point I guess) causing the silicone to weaken and then the pressure of the air inside forces the weakened pipe outwards which results in splits. Apparently the same goes for intake pipes (although they get sucked in rather than pushed out)
I would say this applies more to where you were using it on the track Matt more so than dailies due to different heat and boost conditions
Edited by RBrennan25
Yeah, it's the prolonged heat from the track that's a killer mate.
Texi was short bursts, not enough to make it hot enough.
Remember, Nick was laughing at me when I got a 3rd degree burn in my forehead, when it touched the front housing of my turbo, not the exhaust, but just the front. Was probably 250 degrees....
Hahaha lost my shit!! Also just to throw my 2c in with the piping, I got told by Paul at pulse racing that hard pipes are generally a good idea due to the heat from the engine bay (and the boosted air to a point I guess) causing the silicone to weaken and then the pressure of the air inside forces the weakened pipe outwards which results in splits. Apparently the same goes for intake pipes (although they get sucked in rather than pushed out) I would say this applies more to where you were using it on the track Matt more so than dailies due to different heat and boost conditions
Yep i agree... And both splits were on the manifold side i guess which shows it being the weakest point! I thought Texi would have killed it as it should have been even hotter with no airflow through the front etc... Anyway, the shakedown was a success and i am glad i found it here and not all the way down in SA if i was still going to the Nationals!
As the car will start to see more track than street in the near future i have a few changes to make to keep it reliable!
Also have some changes in the engine bay and also the driveline which i will elaborate on soon, i have been working with Jim Berry on the clutch as the gearbox has to come out soon anyway and we are going to change the design a little to make it more suitable for the style of driving i will be doing, Jim has been fantastic as always and is very keen to try out the new style!
Yep, well its the first time its ever had it so i am glad the problem has been found and will be solved!
Haha really? I would have done this --> :rofl: had i known...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
