Ooooo 26/30 with twin hta3076r's?!?!?!
If it doubt... Moar power!!!
But no, i will pull the engine out and check the bottom end though! The car will be off the scene for around 8 weeks at this stage :)
End up working out what that idle problem was?
Not yet... Ill put a smoke tester on it as if i start it now it will just rev high and on a dead cold engine that cant be good! Could be an intake gasket or something but the engine will probably come out so i can clean some stuff up anyway so ill sort it out :) If anything it probably helped me on the day!
Better driver?? Hahaha awesome effort means I need to get semis to beat you now lol
Haha nah just a refined driver :P
Get Semis so we can go have fun! Ill get the RWD going as quick as i can ;)
Two of the Big Bottles? :woot:
So bummed I couldn't get off work for this. (I actually thought it was on the weekend) :/
Would've been mad.
Haha and Harry i need them by tonight!!!
Here we see the GeeTeeTee hunting it's prey in the wild, waiting for the opportune moment to GAAAAAAAAATE :P
Doesn't exactly sneak up on people though, they generally hear it coming :P
So basically it has been a bloody busy few weeks! Unfortunately not enough time for the car BUT hopefully i will be doing plenty to it over the coming months...
One of the things we managed to do over the past few weeks was get our drawer setup sorted, this will make future track days SO much easier... The drawers behind the fridge will become tool boxes that can lift out with the flick of a latch and have handles on both sides so we can take them to the pits if needed... The overall quality is mint!
  • Like 3
So we took the 4WD up to the Barringtons for a play in the snow and i saw this -
And i thought to myself...... I need to get the fkn car going again so i can abide by this road rule!!!!!!!!!!!
  • Like 1
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
