Next on the list was the SAU NSW Tech night with Just Engine Management... Was kind of handy as i had to go there to drop the car anyway -
you need to remove the daily part from this thread... it may as well be a dedicated track nugget, hasn't seen a public road almost all year! :P
Yeah well one day ill get it moved to the Motorsport section as its certainly something i enjoy doing and will be doing a lot more!
that nulon thing seems interesting, but ive done next to nothing to stand out this year and well without 11ty billion KW time attack will make me look bad
Yeah it looks interesting, my aim is for 2015 anyway but if this happened to come up then it would be a good bit of fun! :)
Got an answer out of Mat for the size offsets of his Work XT7s if anyone else is interested.
F - 18 x 8.5 +32
R - 18 x 9.5 +38
Lol about bloody time he says :P
I have had so many people ask me and its only now i have finally checked haha... Thanks for posting it up as a reminder ;)
hmm no wonder you can fit them 285 under the guard you have that extra 8mm.My 275 are like 5mm away from the guard with the struct loaded.
I measured the 275 Hankook RS3 vs the 265 Hankook Z221 yesterday just for interest.
Hankook RS3 275 = roughly 275mm
Hankook Z221 265 = roughly 280mm
Was only done with a tape measure so it wasn't accurate but you can see side by side the Z221 is a bigger tyre!
is it a semi if i it is i was also told by a tyre sho that semis are always wider than they say. Had 255 RSR federals and were same size as my Michelin PS2 265.
Yep semis...
ive got a semi thinkin about semi's
will probs buy myself some 10" rears soon to run some awesome 295's :D
Put up a DIY thread if you do as 275 seems to be the limit for my guards even with the rolling... I assume you could pump the rear guards but i have never tried this...
No major updates with the car at this stage, apart from the fact its running again...
Seat rails should arrive this week so i can fit the cheap seats in to stop the harnesses cutting my neck... That is about all i can say for now :ph34r:
That is interesting, I have 275/35/19 RS-3s for daily and just got 265/35/18 Z221s for track and I swore the 265 Z221s are wider
Yep i only noticed as they were stacked together :) Will explain why they contact teh front guards haha
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
