Ooooo 26/30 with twin hta3076r's?!?!?!
If it doubt... Moar power!!!
But no, i will pull the engine out and check the bottom end though! The car will be off the scene for around 8 weeks at this stage :)
End up working out what that idle problem was?
Not yet... Ill put a smoke tester on it as if i start it now it will just rev high and on a dead cold engine that cant be good! Could be an intake gasket or something but the engine will probably come out so i can clean some stuff up anyway so ill sort it out :) If anything it probably helped me on the day!
Better driver?? Hahaha awesome effort means I need to get semis to beat you now lol
Haha nah just a refined driver :P
Get Semis so we can go have fun! Ill get the RWD going as quick as i can ;)
Two of the Big Bottles? :woot:
So bummed I couldn't get off work for this. (I actually thought it was on the weekend) :/
Would've been mad.
Haha and Harry i need them by tonight!!!
Here we see the GeeTeeTee hunting it's prey in the wild, waiting for the opportune moment to GAAAAAAAAATE :P
Doesn't exactly sneak up on people though, they generally hear it coming :P
So basically it has been a bloody busy few weeks! Unfortunately not enough time for the car BUT hopefully i will be doing plenty to it over the coming months...
One of the things we managed to do over the past few weeks was get our drawer setup sorted, this will make future track days SO much easier... The drawers behind the fridge will become tool boxes that can lift out with the flick of a latch and have handles on both sides so we can take them to the pits if needed... The overall quality is mint!
  • Like 3
So we took the 4WD up to the Barringtons for a play in the snow and i saw this -
And i thought to myself...... I need to get the fkn car going again so i can abide by this road rule!!!!!!!!!!!
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
