Hey guys,
Ever since I got an Exedy heavy duty clutch professionally installed, clutch pedal feels quite heavy especially after 2 hrs drive each way to work.
Would a nismo slave cylinder make any difference? What other ways can I make the clutch pedal lighter?
Also, quite irrelevant to topic, but is there any suspension that I can put on to make the ride softer than the standard r33 gtr suspension?
Cheers!
https://www.sau.com.au/forums/topic/358495-heavy-clutch-pedal/
I've used my GTR as a daily, but only 1 hour trips each way. Are you sure the clutch booster is working? (clutch pedal should be lighter when the engine is on and feeding it vacuum).
I've never been in a skyline with standard suspension.... If the shocks are tired it makes the ride worse.
I think the real problem is you need a new job.. :thumbsup:
I had a an exedy HD safari tuff clutch in my ute, driving 8-10 hours a day, 5 days a week your leg gets stronger after a while and you dont notice it..
So i get a new BT-50 and all i can say standard clutches are f**kin rubbish It feels all wrong ,doesnt bite when i want/expect it too and even though its only done 50oook i want to change the clutch it shits me that much with its lame spongyness.
But guess ill have to wait till it dies which could be a while, I know guy with 330,000kms on his stock clutch :(
Harden up princess..
4 cylinder? ahh you mean sr20det of course.
seriously though, get an auto corolla or something, not terribly interesting but not too bad, and you'll be saving the gtr for the good times. Or a v6 magna if you want something with a bit more grunt
Yeh it's not my legs that are weak lol it's the bottom of my foot that gets sore towards the end of the week. I have no choice where I work currently driving from Bankstown to Manly/Mona Vale it's just a part of hospital rotations lol In 3 weeks time I'll be off to Lismore for 3 months and I will drive up there. I'm a bit concerned about leaving the car at the airport there when I head back to Sydney for the weekend... pretty sure it's gonna get stolen :/
When you're sitting in traffic stationary, you sit with your foot on the clutch don't you?
If you do, STOP IT! You will be screwing the thrust washer in the engine.
If you want a lighter pedal, put a lighter pressure plate in for the clutch.
Otherwise by a MANUAL 4cylinder... They save even more fuel then the autos and stock clutch = light as.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
