  • Replies 804
FYI. I'm organizing a large scale meet in the coming weeks.
There will be a cruise involved and many opportunities for nice pics to be taken...
So if that guy from Singapore who loves r32 could come that'd be excellent..
Ps I expect to see every single one of you homos there.
There will be that game you guys love... Four minutes in the closet or whatever you guys call it
Sounds wicked bro I'll try to make it! And I will bring a spoon for the egg race ;)
So yes few things established...
there are more than a few James's in perth that own r32s and are talking in this thread.
the cruise "for r32s and and anything else that wants to come along" will be on Sunday 24th April heading to Serpentine at around 11:15 from Perth Esplanade car park.
So let me know who's in boys...
Just make sure the dates don't conflict with the Golden Era Imports cruise which Eps is organising. I know there aren't dates up yet but that cruise is going to be the bigger one. :)
My shit is on May 1st it's not a cruise though. There will be a skylines exclusive cruise heading inbound to the event which I will organize,
The event will be a huge meet and show n shine.. With lots of fun surprises to be had
f**kK! Easter and DD...well if that aint incentive to move the date I don't know what is...
Let's change it to one of the Sundays after Easter Weekend...
1st May
8th May
15th May
Let me know if you can make each one and we'll set the date on the day that most people can come.
We're off to Serpentine and Gooseberry Hill btw. Probably better it happens in May so we get some nice cool weather happening :cool:
Edited by EXEMPT
8th sounds good :thumbsup:
Long shot... Does anyone here own my old R32 or know how she ended up? (Ferari red, vertex kit, RB26, the old MAYH3M)
Pretty sure owner is on here somewhere, i recall seeing the 2530's & intake pipes from it for sale not long back.
Edited by endless
Still have to wait on a few more 8ths but that was my pick as well so we're lookin strong.
How bout we post up some hp figures in the meantime or something. Post up dyno maps n shit and we can make this a bit of a r32 one stop shop :mellow:
Someone else can go first. Post anything r32 related in here really.........
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
