What ever rims u like, jap are generally better/ lighter but more expensive but u canget some good looking ozzy made rims with tires for under 2grand. There's no right or wrong really exept for chrome 22"s
  • Replies 804
Griff what coilovers are they?
I'm interested how low the front ones go.
Simon I guess in a track situation where you're trying to set fast time it could feel a bit shit but seeing as the car is primarily used on the road I guess it doesn't matter what height it's at.
I ended up getting the BC - BR's which apparently are in between the street and track level?
They are height adjustable and damper adjustable so my spine is pretty much dust at the moment :D
The things we do to look stupid.
I haven't even got the fronts maxed out yet simply because my rims wouldn't fit. I'm pretty sure that there is about another 20-25mm left in the thread on the coilover.
mitch when i last saw your car it was ridiculously low, i cant even imagine it now,
you must be dragging your ass along the ground haha
and another thing i want to know is how are u fitting 18x10s on it as well. all kinds of crazy.
come around to my house and I'll show you how its done.
Haha plenty of backyard spec guard rolling and a little bit of camber on the fronts along with stretched tyres :)
Disappointing to hear Jimmy.
Would have been good to see you up at the track.
And bubba wouldn't have a clue what you just said so probably not. The frustrating thing is that it only started leaking after I put a brand new one in
Sorry completely forgot about you, still need a hand doing the sway bar? as bubba said bit of goo is the answer
If anyone needs odds and bods for their 32 i'm stripping a 4 door atm for the interior. Theres no suspension components but i have front quarters, reo, abs unit and little bits. Or if you'd like the shell with some LHR damage come take it
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
