  • Replies 482
car should be out of paint next week but has to go to c-red for muffler change, de-cat and rear camber arms for more low. then back to alberts in cannington to have stereo put together so 10th may be a bit too close to have it all done but look when its done ill post up and if people want to make a leisurely drive down to rockingham to come have a look and go for a spin you're more than welcome but would prefer to keep it mint and not drive it between completion and motorvation.
show of 10 hands or im out
Didn't you organise this?? :glare: And you're not going to show up if you don't get 10 cars?? (I would go but have a prior engagement)
On a separate topic - caught up with Jim, Chuck and Tibby last night - the photo below was taken in complete darkness.... go figure! :blink:
Edited by 32godzilla
exactly, but doesnt stop others from going up to mundaring. the only cars im interested in is daniels and yours.
probably better to wait till after xmas so moar ppl can make it.
Then why post stuff up pinch.gif ,
I don`t see why your posting meets only too play games with People :stupid:
not right way too set meets up :cheers:
so i guess you should not post in here as i shall ask for it too be REMOVE READ WHAT IS SAID IN 1st POST :thumbsup:
So ronery.....
Was a good solo drive through kalamunda to the hotel, waited in the carpark for a bit, bailed and saw a white c34 with grey/black front end on the way to mundaring.
Did U turn back to the hotel to say hello but no one was there so went to freo for lunch...
Next time.
great work, Jim shadow man lol,
good night out with lads & Lasses,
need to do it again Jim maybe few more may come,
get a date set Jim & we will head your way & hit the road.:cheers:
So ronery.....
Next time.
:action-smiley-069: That was me was running late saw you going the other way..... got there and no one around thought missed it so drove the twisty roads home.
try to catch up next time.
later
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
