Lads & Lass`es JDM run on this coming SUNDAY
Sunday, January 15, 2012 12:00pm until 4:00pm.
JDMWA's first event for 2012 will be held on the 15th of January, JDMWA #5 Photoshoot Meet/Cruise.
Meetup at 12pm meet for a 1.30pm cruise departure from Karrinyup Shopping Centre Upstairs Carpark.
Reason being for the longer meet is that we have had a lot requests to make the meets longer for more photos and time for people to have a walk around/come down for a look
afterwards iam heading to any BBQ in arear to have a feed so your call on what happens after,
Cheers Chuckie.
PS there is a few Stagea going so hope few may come along ,
  • Replies 482
also dose any1 know what rear rotors and pads fit a s1 stagea?
can get the rotors from duncan nissan for $140 each
and rear wheel bearings where can i get some? nissan was telling me that i have to get the full hub as well. there $300 each form nissan.
was going to front rotors and pads but thinking of changing it to r33gtst brakes
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
