  • 8 months later...
What problems you have with windows 7?
I tried to load FAST from a disc but can't get it to work. I have been told that it will work on XP and I should run a version of XP within my Windows 7 but that's a bit beyond my computer expertise so I have left it for now!
  • 3 months later...
  • 4 months later...
Here is what I did and this works in windows 64 bit systems so no messing around with virtual windows setup which is a pain in the ass.
NISSAN FAST 2010 and A1, A2, A3, B1, B2 CDs
This will install on 32-bit and 64-bit systems.
http://depositfiles.com/files/c3dqowelq
(this will be approx. 1GB in size)
Instructions
  • Open the NISSAN_FAST_2010_A1_A2_A3_B1_B2.zip file.
  • Extract/Drag the 'NISSAN' folder to your local disk (E.g. C:\ drive).
  • Navigate to 'C:\NISSAN\FASTPRG\WIN2000\SETUP' and open 'SETUP.EXE'.
  • Click 'Next' a few times and complete the setup.
  • Navigate to 'C:\NISSAN' and open 'Nfset'.
  • Select the 'CD-ROM SETUP' tab and add all CDs from 'C:\NISSAN\CD' (A1, A2, A3, B1, B2) by selecting 'Browse' for each drive number.
  • This step is not necessary. In 'Control Panel' open your 'Fonts' folder. Click on 'Font Settings' and make sure 'Hide fonts based on language settings' is unchecked. While in Nfset, click on the 'ALL' tab and select 'MS Gothic' as the font and script to Japanese
  • Now open 'Nissan Menu' from the Start menu.
Hopefully I've explained this as easy as possible and didn't miss any steps.
Cheers,
Ants
  • Like 1
  • 3 months later...
Instructions
Cheers,
Ants
this works a treat........now gotta learn how to play......not sure what step 7 is meant to do though?
step 7 is only to convert the Japanese text into readable English text.
Thanks Ants
No probs.
  • 3 months later...
Just for everyone's information, the link works fine, however you need to just be sure you click on the appropriate download field which is labelled 'Download File in regular mode by browser' (this is the slower connection)
It also works without any issues on Windows 8.1 because I just installed myself :)
If anyone has any queries just let me know.
Cheers,
Ants
  • 3 weeks later...
Just out of curiosity. Does the above version have all the gearbox illustrations for R33 gtst? My files dont have this for my car, they are just blank pages that say something about not available
If they work I'll use the above link and swap out my a1.a2 etc files :)
the answer to that question is....................
yes it does mate :)
yes it does mate :)
slave cylinder and manual transmission illustrations come up with "illustrations cannot be found"
? :S
Do I have a strange VIN or something lol. Anyone got a 33 and been able to look at manual trans illustrations?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
