  • 8 months later...
What problems you have with windows 7?
I tried to load FAST from a disc but can't get it to work. I have been told that it will work on XP and I should run a version of XP within my Windows 7 but that's a bit beyond my computer expertise so I have left it for now!
  • 3 months later...
  • 4 months later...
Here is what I did and this works in windows 64 bit systems so no messing around with virtual windows setup which is a pain in the ass.
NISSAN FAST 2010 and A1, A2, A3, B1, B2 CDs
This will install on 32-bit and 64-bit systems.
http://depositfiles.com/files/c3dqowelq
(this will be approx. 1GB in size)
Instructions
  • Open the NISSAN_FAST_2010_A1_A2_A3_B1_B2.zip file.
  • Extract/Drag the 'NISSAN' folder to your local disk (E.g. C:\ drive).
  • Navigate to 'C:\NISSAN\FASTPRG\WIN2000\SETUP' and open 'SETUP.EXE'.
  • Click 'Next' a few times and complete the setup.
  • Navigate to 'C:\NISSAN' and open 'Nfset'.
  • Select the 'CD-ROM SETUP' tab and add all CDs from 'C:\NISSAN\CD' (A1, A2, A3, B1, B2) by selecting 'Browse' for each drive number.
  • This step is not necessary. In 'Control Panel' open your 'Fonts' folder. Click on 'Font Settings' and make sure 'Hide fonts based on language settings' is unchecked. While in Nfset, click on the 'ALL' tab and select 'MS Gothic' as the font and script to Japanese
  • Now open 'Nissan Menu' from the Start menu.
Hopefully I've explained this as easy as possible and didn't miss any steps.
Cheers,
Ants
  • Like 1
  • 3 months later...
Instructions
Cheers,
Ants
this works a treat........now gotta learn how to play......not sure what step 7 is meant to do though?
step 7 is only to convert the Japanese text into readable English text.
Thanks Ants
No probs.
  • 3 months later...
Just for everyone's information, the link works fine, however you need to just be sure you click on the appropriate download field which is labelled 'Download File in regular mode by browser' (this is the slower connection)
It also works without any issues on Windows 8.1 because I just installed myself :)
If anyone has any queries just let me know.
Cheers,
Ants
  • 3 weeks later...
Just out of curiosity. Does the above version have all the gearbox illustrations for R33 gtst? My files dont have this for my car, they are just blank pages that say something about not available
If they work I'll use the above link and swap out my a1.a2 etc files :)
the answer to that question is....................
yes it does mate :)
yes it does mate :)
slave cylinder and manual transmission illustrations come up with "illustrations cannot be found"
? :S
Do I have a strange VIN or something lol. Anyone got a 33 and been able to look at manual trans illustrations?
    • Post picks of your hanger and pump setup as I have above.
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
