Have you got the folders with the books in them somewhere in their subfolders (a1, a2 etc)?
You need to go to NFset.exe I think it is and manually select the books. I think there are 8 slots, but theres enough for the JDM books anyway. one book on each line
Once your in NFset you should see the file path line and you can browse to select the folders
Make sure you have all the A's and B's from memory in there (one folder for each line) then try again
Are there folders in the A1, A2 etc or do I just select the whole folder eg A1, A2 as I have done, I'll check over it in the morning when i get on my pc, also if I didn't do the folders correctly would the parts show up if you enter the model manually as that works for me at the moment.
No just need to select the A1 folders etc.
Seems odd. I do recall there were certain vins that didnt work (but I thought these were pretty rare) so maybe try another VIN. Is it possible the R34 VINS being looked for are from later on then the year the books go up to? Say for instance if they are a 1999 copy of the parts books but you are looking for a 2002 model?
no idea just a thought
  • 3 weeks later...
Here is what I did and this works in windows 64 bit systems so no messing around with virtual windows setup which is a pain in the ass.
NISSAN FAST 2010 and A1, A2, A3, B1, B2 CDs
This will install on 32-bit and 64-bit systems.
http://depositfiles.com/files/c3dqowelq
(this will be approx. 1GB in size)
Instructions
  • Open the NISSAN_FAST_2010_A1_A2_A3_B1_B2.zip file.
  • Extract/Drag the 'NISSAN' folder to your local disk (E.g. C:\ drive).
  • Navigate to 'C:\NISSAN\FASTPRG\WIN2000\SETUP' and open 'SETUP.EXE'.
  • Click 'Next' a few times and complete the setup.
  • Navigate to 'C:\NISSAN' and open 'Nfset'.
  • Select the 'CD-ROM SETUP' tab and add all CDs from 'C:\NISSAN\CD' (A1, A2, A3, B1, B2) by selecting 'Browse' for each drive number.
  • This step is not necessary. In 'Control Panel' open your 'Fonts' folder. Click on 'Font Settings' and make sure 'Hide fonts based on language settings' is unchecked. While in Nfset, click on the 'ALL' tab and select 'MS Gothic' as the font and script to Japanese
  • Now open 'Nissan Menu' from the Start menu.
Hopefully I've explained this as easy as possible and didn't miss any steps.
Cheers,
Ants
Hey mate
Is the link in this still good??
Not working for me...?
Cheers
  • 8 months later...
Up top there is an icon, looks like a book i think. Hover over it and it should say p/no search
Press that
Hey man thanks for the reply, yeah I figured that out just before noticed it in another thread lol, and this whole time I was thinking the Nissan I go to are stupid because the part numbers never worked, turns out I haven't been giving them part numbers lol.
  • 6 months later...
Worked for me, only difference is I didn't have MS Gothic so used Courier font and so far it looks fine.
[it took me a while to leave XP....lol but eventually I had to bend to the winds of change so skipped straight to 10]
And if you have issues try downloading early in the morning, only took me 1 1/2 hours [and I'm on a really slow connection]. I did try at night but it kept stopping and was really slow [+8 hrs], so I gave up on that.
  • 1 year later...
Hello peeps,
I have been running FAST for years but I recently got a 2004 model car, and my A1/A2/A3/B1/B2 CD set are only 2001 so it doesn't show up.
I just spent 2 hours downloading and extracting the "2010" version only to find out it too has the 2001 CD's. I am 18 years IT veteran and I know what I'm doing in the config files and I used a new directory for the "2010" files, and changed my Directory Setups to the new directory, but I confirmed this as the files in the new "2010" directory have 2001 dates! The same as my old "CD" directory files!
Can anyone confirm they have a CD set newer that '2001/10', (/Help/Version Info) and if they do, where I can get it from?
BTW, my version says v3.50 and I'm running on Windows 10. I have heard there is a ver 5...Is that true?
11 hours ago, sin- said:
Thanks heaps, awesome, it works...just have to start in the menu each time, and select 'AR' or 'JP' depending on the vehicle.
I think I should have probably uninstalled and removed all the older version first, but it went in 'over the top'. I wanted to install it in a different directory, but it didn't let me and put it in C:\Nissan again, like the old version.
  • 3 years later...
I've found a better font for Windows than MS Gothic, that displays Japanese script well.
MIGU 1M (Monospaced)
I tried MIGU 2M, but 1M, regular, in 11pt size, and ensure you set Script to 'Japanese', not 'Western' (using NFSET utility)
It's much better than MS Gothic, I think.
This is Win10,  1920x1200 screen.
  • 7 months later...
  • 9 months later...
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
