Anyone got any idea whats the difference between these 2 other than the cost (standard is around $300 cheaper)? Is it worth the extra if you're just after 300kW or potential 400kW at the wheel? The reason why i've gone with the twin and not single is because of the ocassional launches. Check (if you live in usa): CVS Weekly Ad, or Myer specials. I'm assuming the twin will be bullet proof at that power with launches. One more thing is, the main reason for going with the Nismo is comfort and reliability. If the standard one does the job and is easier on the foot, I would choose that over the competition one. Cheers.
https://www.sau.com.au/forums/topic/359853-nismo-coppermix-twinplate-clutch/
The Nismo coppermix twin is an awesome bit of kit - most of the vic track gtr's run this clutch including mine. Supposedly the competition is rated for higher kw's but I pretty sure the std twin has been used by gtr's in the mid 300kw at the wheels mark.
340rwkw previous - 1.5 years.
365rwkw currently (1 month).
Nismo Coppermix normal here. I've done a silly amount of launches in the last 6 months, works fine and has no issues at all.
Now for the waffle...
It is SOOO much nicer than my OS Racing Twin that i have in the GTS-R having not driven it for 4 or so months... My god it's so hard to drive >_<
Although that said after 15mins i was fine. But sometimes you don't realise just "how much better" some things are.
Only issue is they are not rebuildable like other clutches, although i believe someone is looking into that possiblity.
OS twin rebuild was i think 1400 vs over 2k for a Coppermix. IMO the extra is worth it for a street car
Looks like nobody's got the competition model. The other problem is Nismo doesnt offer warranty for the competition model even though its more expensive and supposed better (471kW for standard and 574 for competition on the datasheet).
Thanks for the feedback guys.
Normal BCNR33 super coppermix; 471kw/640hp, 950kg pressure, 2.08kg lighter than stock C spec version; 574kw/780hp, 1150kg pressure, 2.08kg lighter than stock
Thanks dude. I saw that in the datasheet but I'm more interested in the comfort comparison. The extra power capability is good to have but I wonder if its any harder than the standard clutch. And from the review, most people have the standard one anyway. A bit off the original topic, this is what I've posted on another topic. Any opinion on what to do?
I experience crunching from 3rd to 4th on high rev (e.g. 7000rpm). It does go in but you can hear the crunching noise. However, this only happens on load and never when I shift below 6000rpm. <BR><BR>Another problem which happened ages ago and only once was grinding noise when engaged in reverse gear after a drag day. A quick summary of what happened that day was 3x 6000-7000rpm launches and grinding starts. Drove the car nicely and after that day, the sound went away. Might be something loose from heat expansion? <BR><BR>I know its a million dollar question but if it was you, would you rebuild the gearbox or would you just try using redline? I am planning to change the clutch if that helps making the decision. Rebuild by my mechanic was quoted around 1.5k - 1.8k (everything included except for buying the clutch)
The C spec in my experience is pretty damn close to the same driving wise. Its not like there's the difference of another plate in there.
If the standard one will do for your power, just get that and save the $300.
Before a rebuild of the box, use redline and see if that fixes it. Well, its not a fix, more a band aid until you can be bothered bilding the box
I have the C spec in my car. 400RWKW, has been in the car for the last 6 years. Trackdays, hillclimbs and one DECA plus just flat out disrespect for the thing and it feels no different to the day I got it.
I have the Nismo slave on mine also. Some people swear black and blue that you cannot run the Nismo slave with these clutches..... I have and I wont be changing. Do it, you wont be disapointed!
I've run both the Normal BCNR33 Super Coppermix; 471kw/640hp and now run the C spec and hardly any difference in pedal feel whatsoever.
Just ever so slight more stiffer pedal feel but you can hardly notice the difference. Both feel like the stock clutch very, very easy to drive.
They are a good clutch, but having driven a GT-R with one, I can honestly say I wasn't a fan.
Got back into my own car with OS twin plate .... heaven :wub:
The OS is totally different though. Bites ridiculously hard and has play.
You can feel the coppermix actually giving a bit of "leeway" to the drivetrain even on savage changes, as in it just doesn't bite as hard which for anyone that uses the car moderately often i think is better. You can slip it much easier too where i found OS took a good 500rpm more in the 31 (25box).
Each to their own though. I'll never go back to my OS lol, in RWD it's a pain... with 4WD it'd be too much effort.
Excellent.
Just what I'm after.
l have had os giken and now a copper mix (car is making a over inflated 380rwkw), l would rather the os giken although it is a little heavier to use l find it had more feel and you could ride it more in traffic where the copper mix l find it is either on or off.
I thought its the other way round? Doesnt easy to drive means you can ride the thing?
Thanks guys. I've got the answer I need but I might pay that extra 300 and rebuild the box just to forget about the whole system in the future.
I have the competition model..........................in its box in my cupboard waiting to go into my car :)
I used the normal version in my last R33 GTR and it was brilliant on the street, at the drags, whatever!
Fair comment,
the OS admittedly bites very very hard, that redline to 2nd gear snap where you can just hear the "thunk, chirp" sounds brutal.
but honestly I never had any issues even in bumper to bumper traffic, well maybe it was a bit jerky (the higher revs you talked about) but overall I really like my clutch and did not like the nismo at all !
it had a super high friction point eugh.
Also probably should be noted I have a Nismo master cylinder on mine (bigger one) so that makes it more comfortable on the foot, although I don;t really get the people who whinge about having a heavy clutch, unless of course you have a leg injury/sore foot etc.
Had a coppermix single on my 300rwkw build and it was excellent, only probs i had with it was riding it a touch at high revs to save the drive line (didnt really like that):whistling: Though i did perform an 8 grand launch side steping the clutch and it gripped up sweet and went like a rocket
Now chosen to go the coppermix twin plate for my 400rwkw build, should be a strong and streetable clutch....Cant wait to get it on the street!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
