After following this thread for a while now it was amazing to finally see this in the flesh being competitive.
Here's one of the shots I got while it was on track!
Good work guys, keep at it. ;)
great pic :thumbsup:
thanks
  • Replies 743
diagnosis is in on the gear box problem, broken gear selector - a standard Nissan part.
the boys from Just Jap did suspect this when we discussed the issue with them over the phone on the weekend.
And here is what that Nissan selector fork looked like!
Steve
How about Winton for the SAU Nationals! :) (With a side trip to PI along the way)
Hi, Mark, Andrew and all
I have been follow this thread and Drew's one since day one. my daily fix!! Enjoy the WTAC very much. Unfortunately, our drift car got written off in practice.It would be great if you can come down to Melbourne for the SAU Winton and PI. With more time to sort out the gear box and everything associated with highly modified cars,it will be really flying. 1:35 in PI?
Alex
At least it didn't take anything else out when it failed...
As other have said; Congratulations are in order for the amazing performance of a driver learning what must've been basically a completely different car; and also the performance of a freshly built car. So many variable to contend with, and yet it still shone.:worship:
Well done to all involved; you have much to be proud of.
Edited by Daleo
nice pic guys.
good to see the two GTR's cross the line on the last lap of the event! even if Drew and I didnt trouble the scorboard with our antics
when are you guys planning to be back out on track again?
Just looking at the pic a little more. You can see how the difference in aero works.
at about 220kmph my front sits lower and marks rear sits lower... or it could just be my eyes... Or maybe I just took my
foot off the gas which is possible.
Our aero guys would probbaly like this picture
yes plenty of pics which show our front downforce imbalance from the weekend. we knew this but struggled to correct at short notice despite pulling out rear downforce and adjusting rake angles etc
car looked and sounded AMAZING. crongtats to the team.
have some pretty decent vids. will upload them soon.
was standing behind the car and staring at it up close for a while and on of the mecury motor sports guys was like "you from sau?" and i was like ye...his like "you can touch it"
hahahahahaha
once again awesome car. all the best for next year :D. will deff be up again
Your incar video shows (sounds) the splitter to be contacting the road at about that point of the track - it must be speed/downforce related. Did either of you guys run shock/ride height sensors to the dash logger etc?
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
