  • Replies 743
  • 2 months later...
Things are in motion with our planned modifications for next year.
Very exciting stuff.
small plug for the mercury lads, they deserve it....:thumbsup:
http://speedhunters....otorsports.aspx
cool link - gives me a quick taste of the workshop, thanks for sharing
  • 3 weeks later...
I only come to this section to see updates on this car. did you find out what caused the gearbox failure? have you figured out how to remove the stereo yet?
apparently due to the B clutch over heating by slipping. this caused extreme heat in the b clutch housing (tightened and locked with loctite).
as a result of the heat the housing has loosened and the clutch would not operate so the gear selector is trying to engage without releasing the clutch which resulted in the broken selector fork.
not sure why the clutch was slipping.
two things thought to contribute to slipping are incorrect torque tables and left foot braking. our torque tables were spot on and we uncovered no overlapping left foot breaking on review of both mine ad Tarzan's data.
  • 3 weeks later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
