The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
ID 1600's 2000's. Do it. You will never have to think/worry about it again. Sell the 700's and the changeover will not be that bad. :thumbsup:
I found ID1000's for a bit over $ 100 US each, reasonable ?
im interested in where u got those prices as well - there are some fakes floating as well so need to be careful when purchasing
Just be careful on where you get them. I was told mine were ID2000s but are really Bosch 2200cc. They are pretty much the same injector just not modified like the genuine IDs are
so are the id's modified bosch items? what is the difference?
Mine arent genuine ID's either, they are the local Xspurt modified ones but at $650 who cares. They are 1000cc Bosch EV14 injectors with a guaranteed spray consistency, local warranty and they idle perfectly. I will be giving them a workout soon.
http://www.xspurtinjectors.com/
Basic Specifications Nominal Flow Rate - 2225cc/min @ 3.00 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Thats straight off the ID website!
And for anyone that has issues with these injectors not being able to idle or what not.... here you go!
The guy I bought them off says they are identical but Injector Dynamics just adds on the fancy anodised tip and charges extra for them.
Let me report back with my results after the tune as most of us are still sitting on the fence. My mate who owns autostyle had a gtr 'dardvl' which made 450awkw back in the day and I think that also had 700's
They are ID ones by the looks of the extender, Keep in mind they are only Bosch injectors flow matched and tested, I asked the guys at AZNEW today when I ordered my proflow fittings, they said theirs come in Bosch boxes and are unmodified.
I had a bad experience with the bosch 2000's one injector flowed 7-8% more at idle and fouled the plug real bad.. Im guessing injector dynamics found the same problem and is probably why they push the flow matched sets that you pay a premium for..
From my experience you will need to run bigger injectors then 700's to make 400kw+. When I was making 374 RWKW I ran 700cc Sards with a duty cycle of up to about 96. At the advice of my tuner (a reputable one)I upgraded to Sard 800's to allow for more headroom. This allowed me to run a bit more boost and make 390 RWKW. Now the dc gets to about 85. This is with a -5 2.7 setup. I wonder why the difference between my experience and some others in this thread? Is it just a difference in dyno readings? I know of others with similar results to mine.
Tim.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
