:blink:
I'm confused. All sounds interesting and stuff but you guys need girlfriends :)
Jokes aside would you mind running those calcs on my new wing? What dimensions do you need other than the basice shape? Can you go by a photo?
Any chance taking me for more spins in this thing?
Sure. It's still got straight pipes on it so maybe a quick spin round the block lol. Car is now at the factory in ringwood. Problem is that it's wheelspin city as tyres aren't up to temp. Kinda pointless but you'll still like the experience haha
Russman how are you going for rear traction?
I went for a track night last Thursday and had nothing... My car was over steering and wheel spinning with any hint of throttle when not in a straight line. Has rear camber at 0.75 and toe 1mm in each side!
Whay tyres have you got? What susp?
My car is very settled in the rear now. I am runnig 265 AO50 Semi's though. It puts the power down very well but my power curve is very progressive. It doesn't ramp hard at all.
Check out my video's and you'll see how well it's working. Nothing fancy with suspension settings. Springs are 6kg/mm I think and shocks are adjusted to soft.
Looking forward to this weekend. I am so going to T-Bone your car through the flip flop. You better pray you are in a different group Boy! :whistling:
haha! Buy a raffle ticket. You might get a hot lap :P
haha! I've got one of those, you know it actually turned out to be cheaper to have one than be single and hit the pub every other night :P... plus i love her, of course :ph34r:
Anyway sure thing. basically i need the upper surface area of your wing... so length times width. and a couple of good photos so i can approximate what shape the wing is... really what needs doing, to be accurate, is to measure the chord length, nose radius, maximum thickness, camber of the curve etc. etc., then you can work out exactly what wing shape you have and use the proper lift coefficients.
but approximating is so much easier =P
im feeling a bit zombified at the moment, just finished a 128hr 10 day week. but thats what i can remember at the moment.
cheers, Rowdy.
p.s. Roy be nice!
I'll measure stuff at some point and send it to you.
out of interest, what size rear sway bars are you guys using?
My sway bar setup is Roy's old setup. It's quite unusual and I've had suspension people look at me wierd because of it haha. 27mm front! and 24mm rear. perhaps having very stiff front bar makes the car less oversteery and more neutral through long corners. That's where my car makes up a lot of time. Also is the most fun part of driving round a track :)
Russ - how are you find the G4 356's with he standard rears?
They're great. I love them. I would like to get a bias adjuster so I can make the rears work more but it's very settled at the moment.
My sway bar setup is Roy's old setup. It's quite unusual and I've had suspension people look at me wierd because of it haha. 27mm front! and 24mm rear. perhaps having very stiff front bar makes the car less oversteery and more neutral through long corners. .
Well this weekend was the first time I have driven it with a proper wheel alignment and the ARC swaybars and I am pretty confident in saying the car is slower with the ARC bars.
LOL, if you have any plans of binning yours then let me know. I also have the std Whiteline sizes, but I think I will just go custom again and copy the ones you are running
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
