S A U N S W - Texi, Skids On Sunday, 12Th June 2011
  • Replies 244
I have (possibly) faxed my form through. Sorry to whoever is on the receiving end... the work fax decided to eat the page, forcing me to abort and play tug of war instead. I then resent it and it decided that my daily maximum page quota should be the grand total of "one", and it just sent the page without feeding the second one through. I had to fax the second page seperately... so... enjoy? =-]
Also... it's unclear to me from the above posts... is an L2NS CAMS licence sufficient for this event?
Hey mate,
Nothing has come through yet, if you can try and send it again to be safe that would be great.
Hey mate,
Right. I've resent it today. I could be mistaken, but I think I heard a voice on the other end (very noisy printer room) yesterday and today when I resent it.
Still.. fax transmission log says two pages went through OK.
So... L2NS is acceptable? Anyone?
if anyone needs a fire extinguisher for texi their 2 for 1 at super cheap!!
I also have one for sale (or possibly hire if you have a ratchet for the front seat bolts) that I will bring on the day.
Yep, L2NS is fine, but you'll need to have an L2S if you want to do any track days, so it's better off just to get that.
dammit.. i got defected for having a fire extinguisher in my car a few days ago!
They could only defect you for the location of it or it not being secured, as they're a requirement in government vehicles
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
