  • Replies 86
I am keen to enter provided my car is running, what is latest entry date?
Well I'll be sending an email to members and we will hopefully sell them early next week.... so at this point there's no latest entry date, but I don't expect them to last long. It's surprising there's even 3 spots left as it is.
Yes, how there's 3 spaces left i dont know.
What I do know is, passengers are allowed, timing is included and there's always a BUCKETLOAD of tracktime at our days.
Plus free tuition if you're a noob.
Pretty silly to not come have a go
bring whatever the sr is in kat, fcuked clutch is a great excuse for slow lap times!
Hahaha my NX coupe I'm not even sure that it'd make it to Wakie.
I am a bit guilty of not changing it's oil in a really long time too.
I'm in, who do I have to pay? and how?
Awesome! Yeah the thread is in the NSW Events section, just fill out the forms and deposit the $$$. Maybe just post up when you've done it so we don't give the spot to anyone else!
Money sent I just need to fax the form
Awesome! Yeah the thread is in the NSW Events section, just fill out the forms and deposit the $. Maybe just post up when you've done it so we don't give the spot to anyone else!
Edited by grygtr
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
