I am after a aftermarket high volume sump for my R33 GTR, what do people recommend to get?
Only one I have found so far is the one from Hioctane Racing.
what sort of use will the car have?
In my experience lots of places make big sumps....but not many have acutally competed sucessfully with them in trying conditions. I reckon most of them are not much better than standard.
car will be used for track as well as some weekend drives
i run the trust, just because the pickup and windage tray they use is simple and works well. You must be able to tig weld obviously, so if you can TIG you can probably fabricate a sump - but the pickup on the trust is the deal maker for me
Hey Goeff, can u explain more on the trust pickup please.
  • 1 year later...
x 2 please Geoff!!
For $350 + delivery it's hard to go past the Trust sump...is it the best value for money? Or does it have a major flaw I am missing...
Edited by $$slowmedown
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
