The problem with just changing the resistance...
You still have a 15yo AFM that's most than likely going to fail at some point given just about all of them do.
But new ones and you'll never have to worry about it for another 10-15yrs. AFM issues can often being a major pain in the ass.
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5779385
I got mine done by the same people mate, havent installed them or run them yet so comment on how well they work
the way i saw it was
1. I can either go to the trouble to sell my standard ones, buy second hand z32 ones, screw around with plugs etc
2. Buy genuine nismo ones that are more then $1000 dollars as a pair from memory
Or 3 get them cleaned recalibrated and have them still looking stock and able to bolt straight back up to my apexi intake system... remember though ull need to pay for postage to send your standard ones off and get them sent back
cheers
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5779694
Closer to $750 exchange rate depending
Sell old AFM's for $150 - ~$600 for brand new, high resolution AFM.
Not a bad deal if you ask me. Especially if one of your recalibrated old AFM dies... You are immediately behind in both cost and downtime for the car as you now can't use a stocker AFM to get you out of trouble
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5779761
agree with r31nismoid
airflow meters can fail with age and are crucial for engine management operation
i see no reason to skimp on them when you can buy brand spanker new nismo's off the shelf readily avaiable guaranteed
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5792983
Haha well that's not very comforting! Lol. May have to look into genuine nismo meters then because these re-callibrated ones are $275 or $295 each (exchange for old ones) so like you said if you can pick up a pair of genuine nismos for around $750, sell old ones for $200 you're paying the same for brand new genuine really
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5792993
Go for the NEW Nismo AFM's, i was trying to put off getting them because of the cost.
But really, you have to see the benefits
1 - they fit up as stock (air box, apexi pods, etc)
2 - they're new, so they should last a good 10-15years at least
3 - they allow so much more flow to be reliably measured
My missus WRX had the engine go in it, and it was because it was running stupidly lean because the AFM wasn't reading properly and leaned the mixtures out. it cost her $7,500 for the engine and she still had to get a new AFM. the AFM was a $250 part and because it was stuffed it caused over $7k damage.
the question i asked myself is, do i really want to skimp and save a couple hundred dollars and still effectively run a 20 year old AFM or go for a brand newie and not risk having any major issues caused by the AFM's
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5793549
Would go for ecu with map sensors but want to retain factory airbox etc and only looking to achieve around 300kw atw. Probably cheaper to go something like d-jetro and not worry about afm's but Unfortunatly cops up this way don't take kindly to pods or made up airbox"s etc and an R34 gtr kinda stands out on country roads lol.
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5793761
You just get drama of a different kind to replace it with.
Nothing isn't without drama.
Like what?
Mine's been on map sensor based ecu's since 2 weeks after I bought it in 2005 and havnt had a problem with map sensors.
https://www.sau.com.au/forums/topic/362121-nismo-afms/#findComment-5793789
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
