Turned out to be not neccesary at all. Actually there's a lot of stuff going on around here that's not neccesary IMO... But sometimes just spending the money is half the fun & it keeps the economy ticking over, so it's not all bad.
Because of the wire snip mod?
How about to sort out the A/F?
Leon has his own little DIY interceptors and mods which allow him to do that tuning. He's tried explaining them but I can't really get my head around it without seeing it.
Wire snip gets rid of throttle restriction, but nothing gets rid of the speed restriction short of Nismo, Impul or G-Zone remapped ECUs, and in theory F-con or Haltech PS2000. Still, 180km/h should be plenty fast enough for most people...
.... 180km/h should be plenty fast enough for most people...
Sorry, I should have clarified. If you want to go to the track or live where you won't get locked up for driving faster than 170km/h, then you will need something else.
*cough* :) *cough* :ph34r:
Anyone feel free to complete this sentence:
The best solution for someone that is happy doing under 171kmh, with a front mount, dump and exhaust is.....
:laugh:
G-zone or leons things.
Depending if you want more power...
Well I did the brake wire mod to a mates M35 toady and we couldn't pick the difference from before and after. We ended up rejoining it.
Seriously couldn't pick the difference???
Did you try the "launch" test? That's really the only way to tell. On my car it was really obvious if the brake wire was disconnected or not. Do a test with, then straight away a test without & let us know.
I stalled it up and launched it a few times and couldnt notice any difference, neither could my mate. We both noticed a heap more when I fitted a plenum spacer to mine.
I might try it on mine one day and double check but after the feel of his I'm in no hurry.
With the stock turbo it wouldn't be that noticable, remember they come on at 2k. With a highflow it makes a huge difference.
The best thing about the wire snip is coming out of corners on full throttle. Drive it around for a few days, not just a poofy launch or two. :P
  • Like 1
I'm running the stock turbo & it's still very noticeable on my car. And as Scotty said, not just a "poofy" launch, but driving out of corners as well (roundabouts can get particularly fun now).
However, the launch is an easy way to do a back-to-back comparison.
For example, with my brake wire connected, when I hold the brake on and floor the accelerator, the engine revs to stall (can't remember exact rpm) and just sits there waiting for me to release the brake.
With the brake wire cut doing the same thing, after a few seconds the back wheels (well probably just one, lol) starts spinning and the take off is much more violent with tyres scrabbling for traction. Very easy to spot the difference.
Its simple, cut the wire, extend it to the dash somewhere and fit a switch you can hit while braking. That will reset the CEL and eventual limp mode. Another way would be to run a little relay off the foot handbrake.
Yeah off of the footbrake is more what I was thinking about. Basically the wire needs to be "uncut" and the brake pedal pressed to reset the CEL/limp mode?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
