  • Replies 99
Another Update: The standard radiator looked like it was starting to give way at the top tank, so it would have cost 170 to install a new top tank or 180 for a brand new alloy 52mm radiator.....you do the math :)
i ordered the rad from ASI in melbourne, pretty good to deal with and fast with the shipping, although the 52mm was not available for quick delivery so they sent me a 40mm one with a set of blue silicon hoses to make up for the difference.
anyway....here are some pics!
sitting in there nicely, still have to fit the shroud. at the moment temps are the same as stock radiator.
Enjoy and comment :D
Some more Decent pics from the weekend with the new shoes on!
Maybe go a bit lower?
:D
I'm loving the new look of the car! cant wait to get it out on track, still having coolant leakage issues though, coming from below the new plenum....not sure what im going to do yet.
  • 3 weeks later...
hey mate: nah it didnt bolt straight up, its basically a universal TPS, so i drilled out the centre pin and did a bit of lathe work to make it all fit up tight, its about 1 hours work at your local machining / engineering shop roughly, i think thats how long it took me.
  • 3 weeks later...
Here is a quick update, my girlfriend was nice enough (as usual) to spoil me and buy me some 6000K HID's for my car as one of my presents!
so i finally took the time this weekend to install them with her help for the wiring (little hands)
Let me know what you think!!! i love them.
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
yeah i have ordered pure white LED parker bulbs, interior bulbs, reverse bulbs, number plate bulbs and strobes for the front bar all in LED :) cost me $13 including postage for all that haha
Your build is coming along nicely mate! Where did you purchase the LED's from so cheap??
Rod..
hey mate, read right through the thread and thats an awesome looking car, just wondering about your wheels, im in need to run 265 all around so is this what your running and how much work did it take to get tyhem to fit??
also why do you run the spacers is that for brake clearence????
  • 1 month later...
^^^^^^^ hey mate, thanks for all the positive feedback, love to hear it. nothing much has happened to the car recently seen as though i just got back from a 1 month holiday. i have polished the intake pipes, cleaned up a few bits and pieces along with fabbing up a stainless steel return line :)
My old wheels had 265 rubber on the rears and it never scrubbed but they did have pretty fail offset, the new tyres are 245 but very aggressive offset, i had to run spacers on the front because the offset wasnt quite enough to clear the huge factory calipers.
taking it to QLD raceway on the 31st of August, hopefully she goes well. will keep you all posted
  • 1 month later...
So a bit of a news update seen as though it has been a while, unfortunately i have no pictures to upload though as my iphone crapped itself.
I took the skyline to QLD raceway for drift night a few weeks ago for her first time, the car went very well and didnt miss a beat, the only probably i had was the diff kicking one wheel from time to time which is expected for a factory diff. so i took the car to a mates workshop called workshop one....any gold coast guys should add him on facebook as he does great work and very professional. he took the diff out for me to weld the centre up, gave it all a good clean and put it back in WHOA what a big difference that made!! very excited to take the car to QLD raceway again for a drift night.
Next up is rear camber arms and solid rear cradle bushes!
will keep you updated.
  • 4 weeks later...
UPDATE:
received my R33 rear camber arms by KKR, i put them in the following night along with 7mm steering rack spacers. Yesterday i took the car to nerang tyre and mechanical to get a wheel alignment, the guys down there do a great job and adjust all the arms to set the car up for whatever application you want, turns out i had almost 6Degrees of negative camber on the rear!!! lets just say the car drives much better with only 2deg of rear camber as well as having toe adjustment on the front etc. anyway here are some pics!!
BEFORE CAMBER ARMS
AFTER CAMBER ARMS AND ALIGNMENTS
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
