bought a project car (r32 gtr). finally got it up and going and its not hitting boost - at all
has hi mount t66 and external gate, boost tap, and power fc, stock bov (currently vented to atmosphere :( )
now i blocked up the bov's to see if they were leaking - still no boost
fiddled with the boost tap up and down - still no boost
rev the car, take it for a drive - wont make any boost whatsoever - not even 1psi
anyone have any ideas why it could be doing this.
only thing i can think of is faulty wastegate but when i had it off the car the spring in it had plenty of tension (gate was hard as f**k to push down)
please help :(
https://www.sau.com.au/forums/topic/363602-no-boost-r32-gtr/
The stock bov should be Plummer back but if it isn't it only really effects idle etc it's not going to completely stop it boosting. And to address this issue I blocked it off. There's no funny sounds. I've checked te ic pipes but will go over them again as i may have missed something
No boost at all but still drives with power fc afm etc tells me there shouldnt be any air leaks.
Either turbo's not spooling or the wastegate is completely open which should still make some boost.
Take the wastegate pipe off and see if the exhaust is exiting it.
Is the engine timing and all the basics set correctly?
Has the power fc been tuned before?
Take the dump pipe off and start the engine. See if the turbine is spinning and increases speed with the engine rpm.
Are the wheels still intact with fins?
Have u tried a different boost gauge?
collapsed cat would still make boost, just not do anything with it.
Can you hear the turbo spool up?
Have you confirmed that it definitely isn't making boost and that the issue isn't with the boost gauge? Stupid question i know but i have seen it happen.
Put it on a dyno. you'd be suprised what you can see when you look at the engine under load.
doesnt cat a cat. rest of exhaust is fine. definitely doesnt boost, or even try to boost.
take it for a drive and it just climbs through the revs fine until you change gear. only problem is it doesnt spool 1 bit,
its as though someone is opening the wastegate as soon as it makes boost, but am 99% sure this is not the case (see posts above)
going to check the fueling of it today.
thanks heaps for input - any input is really appreciated at this stage :(
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
